Old 05-04-2008, 08:28 PM   #1 (permalink)
knight is on a distinguished road
Default Quick question
On the Home screen when you scroll up or down there's a solid color line from where your looking.. is there a way to make that bar transparent to see my background? (so it doesnt cover it)
knight is offline
Old 05-04-2008, 08:41 PM   #2 (permalink)
huh?
can you give us a screen shot?
Old 05-04-2008, 08:46 PM   #3 (permalink)
sorry i cant (but if you make your phone go to windows default for scheme. and when you scroll up and down (to see calender,messages .ect) the whole horizontal section is highlighted in a solid color which covers my background. the solid bar was wondering if it can be transparent
knight is offline
Old 05-04-2008, 08:49 PM   #4 (permalink)
docmac129's Avatar
U have to change the xml code from bgcolor="something" to bgcolor="transparent" in each plugin that gets highlighted with the horizontal bar.
docmac129 is online now
Old 05-04-2008, 08:51 PM   #5 (permalink)
you could you would just have to install a screen shot software
didnt realize that is what you are talking about...then yes follow docmacs advice
Old 05-04-2008, 08:57 PM   #6 (permalink)
where do i find that at.. and how would i change it?
knight is offline
Old 05-04-2008, 08:59 PM   #7 (permalink)
the file is located in \application data\home
and just copy it to the PC and use notepad to edit the xml file
save it then put it back
Old 05-04-2008, 09:01 PM   #8 (permalink)
docmac129's Avatar
Post the HS file that u r using & i will make the changes for u. It would take about 10 min. To upload HS file, Save file as i.e. myhomescreen.home.txt & upload in your next post.
Or look in Application data>home for the HS file u are using, copy to desktop, right click> edit, scroll thru xml & look for bgcolor="something" in each plugin and change to bgcolor="transparent".
Old 05-04-2008, 09:08 PM   #9 (permalink)
right now im using the simple.home
knight is offline
Old 05-04-2008, 09:13 PM   #10 (permalink)
docmac129's Avatar
Do u have a Q9 (c,h,etc.?) cuz I have the regular Q and don't have that file. The only one I have is Windows simple, & I don't think that that is the same 1 u r using. Hence, I can't modify it for u. Either figure out how to copy & upload it to here so I can mod it, or if someone with that HS can upload it so I can change it, then it will be done. If not, No can help!
