Old 06-13-2008, 03:31 PM   #1 (permalink)
Tyrrell is on a distinguished road
Default Question about XML Coding
First of all, before I even say anything I will say the theme I am using is one of Eko's theme's, specifically the Punisher one and I was just trying to do some modifications to it.
The only thin I didn't like about it was the general message thing, you click it and it takes you to your message box "Which for my original Q doesn't not include voicemail" so I figured it would be easy, I just take some parts of codes from the themes that come on the q, and add it to the XML for the punisher theme.
It worked, but now the Vmail is one notch higher than the e-mail and text, so it looks weird
<!-- Voice Mail PLugin -->
<plugin clsid="{DCE58428-275E-491f-B835-F2AC38D0CC17}" name="voicemail" height="20" width="320">
<label y="4" x="38">
<format state="unselected" halign="left" bgcolor="transparent" fgcolor="#FFFFFF" font-weight="normal" font-size="16"/>
<format state="selected" halign="left" bgcolor="transparent" fgcolor="#eefd00" font-weight="bold" font-size="16"/>
<text><unreadVMail/></text>
</label>
</plugin>
<!-- Messages Plugin -->
<plugin clsid="{2F930BF0-6FE9-4a53-9E17-88E9247BAB48}" name="SMScount" height="20" width="320">
<label y="4" x="97">
<text><unreadEmail/></text>
</label>
<label y="4" x="154">
<text> <unreadSMS/></text>
</label>
</plugin>
That is what I have come up with it works, but the E-mail and SMS is about 20 pixels lower than the voicemail and I cannot for the life of me figure out how to make them even. I tried using various Y co-ordinants, but if you make it too much then the 0, 0 just disappears.
Anyone have any ideas? I'm kind of an XML noob, just learning as I go along
P.S.
This is the original coding for the whole V-mail, E-mail, and SMS line
<background b-border-width="0">
</background>
</label>
</label>
</label>
</plugin>
Tyrrell is offline
Old 06-13-2008, 03:34 PM   #2 (permalink)
did you check this post: http://www.everythingq.com/forum/q-h...als-11322.html
Old 06-13-2008, 03:36 PM   #3 (permalink)
Yeah skimmed through it, but I didn't see anything about seperating V-mail from the E-mail and SMS but keeping it on the same line on the home screen
Tyrrell is offline
Old 06-13-2008, 03:40 PM   #4 (permalink)
TreeFrog's Avatar
2 plugins can't share the same line unless you use Orange...but then with orange one or more may not be selectable!
TreeFrog is online now
Old 06-13-2008, 03:44 PM   #5 (permalink)
uhm... i use Orange, 3 indicators on same line and selectable.
Old 06-13-2008, 03:47 PM   #6 (permalink)
TreeFrog's Avatar
all three are individually selectable? must be that verizon thing!!
Old 06-13-2008, 04:20 PM   #7 (permalink)
Ok so I found Orange, how do I use it? I installed it but I can't seem to find it on my phone now
Tyrrell is offline
Old 06-13-2008, 05:08 PM   #8 (permalink)
docmac129's Avatar
U wont find it. it runs in the background, & it also needs to be written in the code of the xml also.
potq
docmac129 is online now
