Old 02-15-2008, 07:43 PM   #101 (permalink)
spork27's Avatar
spork27 is on a distinguished road
Prosper, I'm testing out your new Homescreen. The only problem I'm running into (and this isn't actually a problem with your stuff) is that I can't get pA to switch Profiles.
**edit**
A reinstall of pA fixed the problem.
spork27 is offline
Old 02-16-2008, 02:13 PM   #102 (permalink)
jndrad's Avatar
jndrad is on a distinguished road
Default testing
Prosper
if you need it, i would like to help test your new homescreen
jndrad is offline
Old 02-16-2008, 03:01 PM   #103 (permalink)
Originally Posted by jndrad View Post
Prosper
i believe the file has been publicly posted so you can go right ahead
Old 02-20-2008, 07:58 PM   #104 (permalink)
jbeef86 is on a distinguished road
Hey Prosper I love your homescreens!!!
I have a question that maybe you or someone else that uses your homescreens can answer. Sometimes when I get an email or my phone voicemail goes off my phone starts to vibrate and doesnt go off. I either have to reboot the phone or pull the battery. You hear of this before? Is it a phonealarm issues? I have no idea.
Thanks,
John
jbeef86 is offline
Old 02-25-2008, 02:04 PM   #105 (permalink)
us3rX is on a distinguished road
Been using your screen for a while, well the new one and i love it, nothing major, but i think i am going to make another color scheme, but overall i love it ^.^
~us3rX
*posted from q9c*
us3rX is offline
Old 02-25-2008, 02:08 PM   #106 (permalink)
xghostx's Avatar
xghostx is on a distinguished road
~us3rX
*posted from q9c*
i know! where is the stk skin? we would be all set with it.
xghostx is offline
Old 03-23-2008, 02:11 PM   #107 (permalink)
Joneyee's Avatar
Joneyee is on a distinguished road
Send a message via MSN to Joneyee
Originally Posted by Prosper View Post
Finished the pA part today and also the missed calls page.
This is how it looks so far. The Facade part will be added in the next days (not sure when exactly).
Thinking about adding the Facade Launcher also, but that'd require custom icons (as the standard WM ones wouldn't look good on that theme). Thoughts? :}
Ok I have been dying to try this homescreen when it is done. Prosper... any updates on your progress??
Joneyee is offline
Old 03-23-2008, 02:13 PM   #108 (permalink)
Joneyee's Avatar
Who's interested?
Especially the voicemail thing needs testing. Also, not sure how the appointment thing exactly works in pA Just give it a try.
=( The download has expired. Anyone with the files I would LOVE to help test this.
Joneyee is offline
Old 03-23-2008, 05:01 PM   #109 (permalink)
Prosper's Avatar
I actually haven't worked on this skin anymore, but here you go anyway.
http://download.yousendit.com/917C08D7007FB99E (I think those should be the correct files)
BTW I wasn't able to answer your mail - mail couldn't be sent.
____________________________________________
Here's another new skin I (I think) have just finished.
Required plugins are phoneAlarm, Facade and Iars Calendar (see my page for download).
Download: http://download.yousendit.com/0AE427B21D52D654
The first skin for my Treo 500v
I think it will be posted on my page in the next days, so it's EQ-exclusive for now.
Prosper is offline
The Following User Says Thank You to Prosper For This Useful Post:
Joneyee (03-23-2008)
Old 03-23-2008, 07:39 PM   #110 (permalink)
Joneyee's Avatar
Many Thanks, It beautiful, and I am testing the other smaller features now.
Joneyee is offline
