Originally Posted by rudeboy the file on the Q is read only mots likely... plus it's better to use a more plain text editor such as Notepad or Wordpad. |
I used notepad to change the file after putting it on my desktop.
How do I take read only status off the files on the Q?
.....wait...I may have just found it.....ok, maybe not. I went into properties in application data and the \application data\home folder is not checked read only but the files inside are. Easy enough, take the read only check mark out...but, the sprint.home.xml file I am trying to change is not listed there but is listed when I have the phone connected to my pc and go through windows explorer.
