Old 04-18-2007, 02:14 AM   #1 (permalink)
Krayzie is on a distinguished road
Default Need some help
Okay guys I'm new to this forum and new to PDA phones. I just got my Moto Q on friday, I was looking around and see you can put custom home screen. Well I don't know how to program this stuff. I made a custom background the way I like it to layout.
The way I have my icon do I need to buy some type of plugin? I hope somebody don't mind helping me with it. All I know is photoshop work haha. Thanks for you guys time
ONe
PS the top right I would like it to have the battery life and signal like how it is now on the Moto Q, I just didnt put it on it.
Krayzie is offline
Old 04-18-2007, 09:18 AM   #2 (permalink)
well i can tell you so far you would need orange.dll to run those icons like that....
Old 04-18-2007, 09:23 AM   #3 (permalink)
Prosper's Avatar
You won't need it for the icons, but for the Iconbar/Time as well for the Appointments/Profile display.
Prosper is offline
Old 04-18-2007, 09:26 AM   #4 (permalink)
to make the usable i thought you did....
Old 04-18-2007, 09:33 AM   #5 (permalink)
thanx for replying back to my request.
So how do I get it going, what I mean is how do I program it and all? I'm so new on this
Krayzie is offline
Old 04-18-2007, 09:40 AM   #6 (permalink)
i would start without using plugins... do that later, a good tutorial can be found here: http://www.modaco.com/Tutorial-Creat...s-t233425.html
Old 04-18-2007, 09:41 AM   #7 (permalink)
Prosper's Avatar
You may wanna start learning a bit xml with w411y's excellent turorial over at MoDaCo.
I can't help with the Orange plugin thing, since I don't use it.
Prosper is offline
Old 04-18-2007, 09:42 AM   #8 (permalink)
ditto...
you sure didnt pick an easy one to start with....
download some other homescreens and check out there xml format to kinda get a a handle on what is what...the tutorial is also a really good way
Old 04-18-2007, 09:48 AM   #9 (permalink)
iight i give it a try. what program you use to edit the xml?
Krayzie is offline
Old 04-18-2007, 09:50 AM   #10 (permalink)
i just use notepad...
