Old 06-05-2008, 03:48 PM   #1 (permalink)
zachass is on a distinguished road
Default Need Help!!!
So, I have done some searching and still can't seem to find an answer, so I am hoping that I can get some help or have my head pointed in the right direction. I have downloaded some zipped backdrops for my Q, but I can't seem to find a way to unzip them, or to access them in my homescreen options so that I can use them. How do I unzip files on my Q? I can see the downloaded zip file in the "My Documents" section of the file manager, but that is it.
In case you can't tell, I am just a "little" ignorant on using my Q.
zachass is offline
Old 06-05-2008, 03:52 PM   #2 (permalink)
PacoJr67's Avatar
transfer them back to a PC and unzip them there. or if you have documents to go it also has an unzip utility
PacoJr67 is online now
Old 06-05-2008, 03:54 PM   #3 (permalink)
read the homescreen installation instructions in the homescreen forum to learn how to install the screens
Old 06-05-2008, 03:56 PM   #4 (permalink)
or unzip them using resco explorer and move the contents to /appliation data/home
bobby-n is offline
Old 06-05-2008, 04:10 PM   #5 (permalink)
So once I unzip the zip file, it will become a cab file that I can then sync back into my phone? Or, it is pretty easy to upload a program to my phone that will allow me the ability to unzip the file?
In case you can't tell, I am very ignorant about these topics.
zachass is offline
Old 06-05-2008, 04:14 PM   #6 (permalink)
google resco explorer.... and yes if its a cab file then just install if it contains a xml file and pictures and suff just do what i said above
bobby-n is offline
Old 06-05-2008, 04:16 PM   #7 (permalink)
jim9112 is on a distinguished road
some homescreens are packaged as cabs but most are not. just unzip files place in directory stated above then it will show up under setting/homescreen. if it unzips as cab place on device and run cab file
jim9112 is offline
Old 06-05-2008, 04:17 PM   #8 (permalink)
just read the file extension and then follow the instructions for whatever file it turns out to be
Old 06-05-2008, 04:20 PM   #9 (permalink)
man everyone is on it today i could have saved myself some typing on my little bubbly q1 keys
jim9112 is offline
