Old 10-18-2007, 05:21 PM   #1 (permalink)
freemouse is on a distinguished road
Default need facade h/s with larger print!
Hi all, i am using facade and fizz, but all the homescreens i can find, especially the ones that came with facade are so dang small i need to pull out my reading glasses (ok i'm 40). Is there one out there that has room designed into it for a bit larger font? even the time on the facade skins are micro. i dont need huge, just not the size of ant poop. thanks!
freemouse is offline
Old 10-18-2007, 06:35 PM   #2 (permalink)
Now that's an idea....
List gets longer....
Might have some free time tomorrow to tackle that one.
Der Alta is offline
freemouse (10-18-2007)
Old 10-18-2007, 08:42 PM   #3 (permalink)
TarHeelsRule!'s Avatar
TarHeelsRule! is on a distinguished road
Have you tried adjusting the print in your facade settings? I too can't see the small print so I change mine to medium font. Haven't tried the large font yet.
TarHeelsRule! is online now
Old 10-18-2007, 08:44 PM   #4 (permalink)
THR makes a very good point, play with the settings in Facade.. font size wise.
nothing wrong with being 40... or past 40 for that matter :}
Old 10-18-2007, 09:12 PM   #5 (permalink)
Yeah, haven't you heard 40 is the new 30!! (this is from a 40+ yr old). You're only as old as you feel!!
Old 10-18-2007, 09:34 PM   #6 (permalink)
hey... i totally agree with you, and yes... young at heart is what matters. (says the other 40+ yr old :}
Old 10-19-2007, 08:52 AM   #7 (permalink)
I did that, but because the homescreen facade space allocation is small, when i make the print larger, i only get 1 to 1-1/2 days to display because they jam the message counts, profile, and too much crap under it. not enough room for just the facade part. 40 rules!
Old 10-19-2007, 09:56 AM   #8 (permalink)
OK, had a quick go at this to see if I could attain a layout that looked good. If this works for those of you with , I'll expand upon it.
"Right Click" and "Save As"
Der Alta is offline
freemouse (10-19-2007)
Old 10-19-2007, 05:03 PM   #9 (permalink)
...nothing wrong with being 40... or past 40 for that matter :}
Whew! Glad to hear that.
-- Motorola Q, WM5, Verizonwireless, U.S.A. --
scottjb is offline
Old 10-19-2007, 08:36 PM   #10 (permalink)
you're welcome... and you didn't need my "approval" did ya :}
