Originally Posted by shaun0207 Ok. I want Facade to show up, but only muy schedule not the task. Does that make sense. |
it does...but it looks like you have set up or trying to set up tasks (just by the title of the facade plugin...but that has no determination on the actual plugin)...
fix that code that i showed you and then you can edit facade while the homescreen is running...
or better yet remove facade code from the xml file and add it through the facade editor on the Q!
