Old 05-20-2007, 03:49 PM   #1 (permalink)
Qryan is on a distinguished road
Rating or review MRU Icon sizes
As I understand things from messing about with xml for the past couple of days, there are only two available options for the size of your icons in the mru. It seems they can either be the small ones like on the verizon homescreen (size 16 or below) or the larger ones that appear in the windows default homescreen. So, I just wondered if this was correct or if one of you that is more experienced than I with xml could enlighten me on a way to size the icons somewhere in between the two.
thanks,
Ryan
Qryan is offline
Old 05-20-2007, 05:19 PM   #2 (permalink)
i believe it is only large or small...i have only seen atleast...most of mine are at size 16...
Old 05-20-2007, 05:25 PM   #3 (permalink)
ok, that stinks, thanks for confirming tho. One other question while ive got you here. There are some of the images in the windows folder that i am trying to edit, but a few of them are read-only and it does not allow me to change this setting. Is there a way around this, or is there some sort of program out there for getting around it?
thanks,
Ryan
Qryan is offline
Old 05-20-2007, 05:58 PM   #4 (permalink)
images in the \application data\home folder?
it could be read only if you have viewed them through file manager...try to kill all tasks and try it again...or power down and try again...
Old 05-20-2007, 07:04 PM   #5 (permalink)
I believe it is a file that verizon purposely made this way so that nobody could edit it. I just wondered if there were any apps out there that allowed you to access it. It is the 16_brick_131.gif file in the windows folder.
Qryan is offline
Old 05-20-2007, 07:16 PM   #6 (permalink)
to edit those you need either total commander or resco explorer...those are files in ROM for the start up screens i think....i remember seeing something like that when i messed with the splash screen....
