Old 06-14-2008, 02:18 AM   #1 (permalink)
flattoprob is on a distinguished road
Default Missed Call Screen Requested
okay I have been told that Der Alta is a very busy person He has awsome HS's along with everyone else he has one that i really like but it doesn't have a miss call screen if any one could hook me up that would be great thanks in advance http://www.omandcorp.com/motoq/der_a..._facade_V3.zip
this is the link to the before mentioned HS again thanks
flattoprob is offline
Old 06-14-2008, 03:59 AM   #2 (permalink)
manbat's Avatar
manbat is on a distinguished road
Default Missed call request
I have added a Missed call screen on DA supermanV3.2on my phone....What image do you want? Or do you just want it black screen? Let me know? I can do it for you if there are no objections from Der Alta.
If Someone Helps You, Please Clickat the bottom of the post!
My HomeScreens: Click Here Here:http://www.everythingq.com/forum/q-home-screens-and-wallpapers/manbats-homescreens-22840.html
omef I
manbat is online now
The Following User Says Thank You to manbat For This Useful Post:
flattoprob (06-14-2008)
Old 06-14-2008, 04:18 AM   #3 (permalink)
What Pic are you using?? black would be great or the superman symbol im not to picky im just greatful for the help
Old 06-14-2008, 04:24 AM   #4 (permalink)
manbat's Avatar
I just have Black screen on the Superman....I'm Building it right now.
omef I
Old 06-14-2008, 04:42 AM   #5 (permalink)
manbat's Avatar
Default Missed Call screen
Two files attached....Built it real quickly alignment might not be perfect. Just add the XML to Application Data / Home along with supermanMC.jpg. It will use the folder for the other xml...they both can be left in. The one I Modded has a different name.
omef I
Old 06-14-2008, 04:58 AM   #6 (permalink)
the mc looks great but I can not open the compressed file to install it says its corrupt
Old 06-14-2008, 05:14 AM   #7 (permalink)
its a great pic just need the xml
Old 06-14-2008, 05:16 AM   #8 (permalink)
manbat's Avatar
Working on it.....I'll repost it
omef I
Old 06-14-2008, 05:31 AM   #9 (permalink)
manbat's Avatar
Try it now.. I also edited the image for a better screen fit. Use the new image.
omef I
Old 06-14-2008, 05:36 AM   #10 (permalink)
Nope its still coming up corrupt tried several thing but still doesnt work also tried opening other file to make sure it wasn't me I appreciate you going to all this effort the pic does look great
