Old 12-10-2007, 03:16 PM   #11 (permalink)
Originally Posted by Spencer-Scott View Post
Ya its there. I tried it and it works. It comes up on a black screen and a blue # of how many missed calls. I got the picture wrong I need to know how to find/type the picture in. I would also like it to say Missed Calls: # of missed calls
put the picture in \Application Data\Home\ and in the code i posted you only have to change the filename.jpg....
Old 12-10-2007, 03:27 PM   #12 (permalink)
Spencer-Scott's Avatar
Spencer-Scott is on a distinguished road
i just tried that and it still isnt working.
I put the image in /Application Data/Home/ and then in the code i named it xxxx.jpg and it still isnt picking it up.
also could you get it to say Missed Calls: # of calls
Spencer-Scott is offline
Old 12-10-2007, 03:39 PM   #13 (permalink)
are you reloading the homescreen?
meaning if you edit the screen you are currently using and then reload the xml file its not going to take those changes
you need to load a new screen up...let it take control..then go back and load up the screen you want this way it can accept the changes you made
Old 12-10-2007, 03:48 PM   #14 (permalink)
? I have no clue what your talkin about im sorry
Old 12-10-2007, 04:02 PM   #15 (permalink)
ok
sorry
after you edit the homescreen xml file do you just put it back on the Q in \application data\home folder and not reload the homescreen?
i have a feeling that you are not reloading
to do this you have to
1. make sure the updated file (xml file) of the homescreen you want is in the \application data\home folder
2. start--settings--homescreen
3. pick ANY homescreen and load it
4. go back to start--settings--homescreens and load the screen you want
this is the ONLY way your updates will take effect...the screens do not automatically update after you change something if you are running the screen you changed
make sense?
Old 12-10-2007, 04:06 PM   #16 (permalink)
yep i did that. It worked, but now the picture is too big is there a certain size it has to be...and still how do you change it to say Missed Calls: #
Old 12-10-2007, 04:10 PM   #17 (permalink)
image needs to be 320x213
as far as putting 'missed calls:' on it all mine are done in photoshop...so the words 'missed calls:' are part of the image then you move the x & y coordinates around so the # lines up
Old 12-10-2007, 04:16 PM   #18 (permalink)
thanks thats really helped
Old 12-10-2007, 04:17 PM   #19 (permalink)
no problem
as always post back if you run in to any trouble or need someone to edit the image for you!
Old 12-10-2007, 07:25 PM   #20 (permalink)
So in the code you posted previously in this thread... where would I put the words "Missed Calls" if my missed calls picture doesn't have it in it already... (did that make sense?)
P.S.
Can you send me some of your "Missed Calls" pictures?
MaRiA
LuvrGirl is offline
