Old 10-17-2007, 09:06 PM   #11 (permalink)
Originally Posted by Kuriakose View Post
ok i did that, buts wen i open it, it takes me to a website not putting it as my home page
make sure what format the file is, i believe it is a .rar which should be unpacked w/ Winrar, that is basic pc knowledge.. i can't really make much of your post..
Old 10-19-2007, 12:24 PM   #12 (permalink)
Kuriakose is on a distinguished road
Its a XML Document type i drag it and put it into Application Data/home on my computer to my phone and then when i try to open it on my phone, it goes to a website and put all this random info down
Kuriakose is offline
Old 10-19-2007, 12:27 PM   #13 (permalink)
Its a XML Document type i drag it and put it into Application Data/home and when i try to open it, it goes to a website and put all this random info down
the .xml needs to go in the Application Data\Home.. together with the image. did you read these instructions ?
Old 10-19-2007, 12:38 PM   #14 (permalink)
Ok i put all the pics in the application data and home now what?
Old 10-19-2007, 12:44 PM   #15 (permalink)
put the image in Application Data\Home (that is a path, you do not have to put them in both directories/folders)
also put the .xml file in that same folder
go to Start Menu > Settings > Home Screens > and select the .xml, set other values to default (color scheme and backgound)
go back after ok or apply and enjoy the screen.
Old 10-20-2007, 12:09 AM   #16 (permalink)
Im really sorry but im still confused theres like 6 images which one? I got it set but only 2 to 3 pics of the screen are there the others are not could u help a little more i appreciate this very much thank you for your patience?
Old 10-20-2007, 12:34 AM   #17 (permalink)
Accordman is on a distinguished road
Send a message via AIM to Accordman Send a message via Yahoo to Accordman
i can understand your plight, i had issues installing it last night and i just ended up giving up
Accordman is offline
Old 10-20-2007, 01:06 AM   #18 (permalink)
Trouble? Hmmmm. When you extract the files, make sure the images inside the folder stay intact. Using ActiveSync, open the folder where your homescreens are located and drag the entire images folder of this homescreen into the folder containing all homescreens. Should let you without any problems. Don't do it image by image, the whole folder needs to stay intact.
Old 10-20-2007, 01:13 AM   #19 (permalink)
sweet i got it man thanks a million
Old 10-20-2007, 02:41 AM   #20 (permalink)
ok i took the GyPairJordan01 Xml document and put it in home and application and then i put the WHOLE entire folder of GYPairjordan01 and then i went to settings and then i put the GypairJordan01 as home screen and im only getting 2 parts of the whole background wat did i do wrong?
