Old 06-10-2008, 06:17 PM   #1 (permalink)
manbat's Avatar
manbat is on a distinguished road
Default manbat's Homescreens
Here is one of the homescreens I have on my Q9m. I take no credit for the XML...it's Der Alta's Superman v3.2 adapted for my images. I created the Images w/ Photoscape (Freeware). I'm in Management for Kroger Stores....so I just thought I would try to adapt it. I really wanted the "Kroger" to be larger in the screen but I'm not really good with Photo Shop so I fell back on the PhotoScape...I couldn't get the schedules, programs, and task buttons to line up right when I cut them out of the Kroger image. I made the image smaller so I only had to cut a "black" image for the buttons.
Needs Facade, Orange, Fizz Weather
You would probably have to work for Kroger to like it...but if anyone does... I'm including the xml and image folder. Just install the xml and image folder in Application Data/Home. Keep the images in the folder.
I usually keep the images files for complex homescreens in Storage Card\Application Data\Home ...on my Q9m. I just edit the xml ...pointing it to the SD Card...it works. This way only xml and dll is in Application Data\Home on my phone....Saves a quite a bit of internal memory.
Here's the image of a missed call screen I just added along with the xml to support it.
Just unzip and add the new image and xml in the attached zip files to Application Data\Home along with the kroger_black images from below .
If Someone Helps You, Please Clickat the bottom of the post!
My HomeScreens: Click Here Here:http://www.everythingq.com/forum/q-home-screens-and-wallpapers/manbats-homescreens-22840.html
omef I
Last edited by manbat; 08-01-2008 at 11:19 PM. Reason: removed original no Missed call XML
manbat is offline
Old 06-10-2008, 07:22 PM   #2 (permalink)
kaylabeers's Avatar
kaylabeers is on a distinguished road
Nice edit =)
kaylabeers is offline
The Following User Says Thank You to kaylabeers For This Useful Post:
manbat (07-26-2008)
Old 06-10-2008, 07:46 PM   #3 (permalink)
right store.... right prices :}
looks good actually...
potQ.
manbat (07-26-2008)
Old 06-10-2008, 08:02 PM   #4 (permalink)
looks good indeed...but is it me or is the animated gif mega fast?
EDIT: ok after it loaded is slowed down
manbat (07-26-2008)
Old 06-10-2008, 11:39 PM   #5 (permalink)
inscracefan24488805's Avatar
inscracefan24488805 is on a distinguished road
Default Like your homescreen.
Just add the new image and xml in the attached zip files to Application Data\Home along with the kroger_black images from the above .
I like what you've done with this homescreen on the edits.
inscracefan24488805 is offline
The Following User Says Thank You to inscracefan24488805 For This Useful Post:
manbat (06-10-2008)
Old 06-16-2008, 05:42 PM   #6 (permalink)
manbat's Avatar
Default Another Screen on my Q9m
This is another home screen I have on my
Q9m.
Needs Orange and Facade Shown w/ Black Soft Keys
..It's modified from this posting. My modified XML is posted in this string....use original image and Missed call screen.
http://www.everythingq.com/forum/q-home-screens-and-wallpapers/fresh-set-from-the-mouse-trap-21700.html
Hope you like it.
I added a zip file with xml and images, attached below.
omef I
Last edited by manbat; 06-22-2008 at 02:36 AM. Reason: Added Zip w/ xml and images
manbat is offline
Old 06-18-2008, 06:25 AM   #7 (permalink)
manbat's Avatar
Default New HomeScreen...Hellboy w/Missed Call screen
Put this one together tonight. I modified the 'Verizon
Wireless" to read "Wireless Manager" it's selectable...
Takes you there. XML is based on the Ironman above.
The missed call screen XML is modded.
Hellboy / Needs Orange and Facade
Missed call Screen
Zip file is attached.
omef I
manbat is offline
Old 06-21-2008, 07:44 PM   #8 (permalink)
manbat's Avatar
Default From Request
Requested homescreen
Needs facade and orange, Shown w/ Black Soft Keys
Enjoy! Zip attached!
omef I
manbat is offline
Old 06-22-2008, 02:06 AM   #9 (permalink)
manbat's Avatar
Default Hulk from Request
Here it is ....Made it Quickly w/ xml I already had. Created HS image...found MC & modded it.
Needs Facade & Orange, shown w/ Black Soft Keys
Missed Call
Hope you like it. See Attached Zip.
Let me know if you like it!
omef I
manbat is offline
Old 06-22-2008, 04:18 AM   #10 (permalink)
manbat's Avatar
Default Mouseboots Avatar--New Homescreen
Your new avatar caught my interest.....SO, I built this.
Needs Facade & Orange Shown/w Black Soft Keys
and the Missed Call Screen
If you like let me know. Zip attached
omef I
manbat is offline
