Old 06-13-2008, 11:40 AM   #1 (permalink)
omg its nate's Avatar
omg its nate is on a distinguished road
Default Line in my screens?
My last issue of the day.
All my screens have this black line I cant get rid of.
Example
It was like that with the default and modified screens...
What did I mess up?
omg its nate is offline
Old 06-13-2008, 11:41 AM   #2 (permalink)
it's in all screen by default and i think there is no way of getting rid of it.. (did you find all the screens you wanted ? Qusers is still down i see)
Old 06-13-2008, 11:46 AM   #3 (permalink)
Well whats the heck up with the line! Oh well.
It was actually up yesterday for a few hours so I got all that I needed!
Thanks
Old 06-13-2008, 11:51 AM   #4 (permalink)
Thanks
yea... n99 has messed with it for a while regarding changing the color of the smaller text, also not possible... kinda of a bummer if you totally want to personalize the Q... ah well.
can you email me the screens, just so i have them. + i will keep checking on Qusers, there are a few threads/posts i wouldn't mind having here on EQ in case they are down again.. (which they are :])
Old 06-13-2008, 11:57 AM   #5 (permalink)
Yeah I will do that once I get home.
Also found this thread here.
http://www.everythingq.com/forum/q-home-screens-and-wallpapers/replace-your-splash-screens-2537.html
Old 06-13-2008, 12:04 PM   #6 (permalink)
manbat's Avatar
manbat is on a distinguished road
I one of the home screen building programs there is an option to change the color of that line...can,t remember it's name but it lets you change splash screens..and colors in volume bar and large text .it puts a folder in Application Data\Home and changes the registry....I'm at work right now...I,ll look when I get home. ......................................... ......manbat, Via Q9m w/ Skyfire
If Someone Helps You, Please Clickat the bottom of the post!
My HomeScreens: Click Here Here:http://www.everythingq.com/forum/q-home-screens-and-wallpapers/manbats-homescreens-22840.html
omef I
manbat is offline
Old 06-13-2008, 04:41 PM   #7 (permalink)
@ nate: that link does not work..
@ manbat: really ? interesting...
Old 06-13-2008, 06:24 PM   #8 (permalink)
yea it sucks you cant change it
i tried and a few other members gave it a go with me and no luck
and i have that line on my screen too...my screen is darker so you really cant see it all that much
Old 06-14-2008, 01:30 AM   #9 (permalink)
manbat's Avatar
Default Ruttensoft Homescreen Designer 2007
Here's what I was talking about.
Ruttensoft Homescreen Designer...it allows custom splash screens to be installed and linked to the home screen color scheme. As you can see you can select the color of the line and the large title text. When you select custom screens it puts them in a folder and puts the folder in Application Data/Home and adjusts the registry. I went one step further and created a Storage Card/Application Data/Home put the folder there and changed the registery to point there. I also keep my custom startup and shutdown screens, my custom startup animations, and all the image files for my home screens there....with xml or registry adjusted to point there(IT WORKS GREAT...SAVES INTERNAL MEMORY). The color scheme lines that change the color are.....COLOR_ALERTTITLE and.... COLOR_ALERTRULE (this is the line)......You can ad these lines and the perfered color to any "color scheme" and the Title Text and Line Color will be changes......maybe there's some way to make the line "transparent" with this info...I haven't had time to figure it out yet. Hope this information helps someone.
omef I
manbat is offline
