Originally Posted by lightning807 one question about the start menu.
when i use the new home screen, navigating in the start menu/app list doesnt have a 'selected' icon to show where my 'cursor' is. With my old home screen there was a dark gray box that went around the icon, but it seems like now there is a white box on a white background, which doesnt work out that well lol.
Is there any way to darken the white background in the start menu or make the box around the icon darker? |
Lightning,
Do u know how to edit the xml file in Notepad on your computer?? It would take all of 30 sec if u do. Just change the 6 letter code for:
<scheme>
<color name="COLOR_WINDOW" value="#FFFFFF" />
<color name="COLOR_WINDOWTEXT" value="#000000" />
<color name="COLOR_STATIC" value="#FFFFFF" />
<color name="COLOR_STATICTEXT" value="#000000" />
<color name="COLOR_HIGHLIGHT" value="#5B5B5B" />
<color name="COLOR_HIGHLIGHTTEXT" value="#FFFFFF" />
<color name="COLOR_TEXTSELECT" value="#FFFFFF" />
<color name="COLOR_MENU" value="#FFFFFF" />
<color name="COLOR_MENUTEXT" value="#000000" />
<color name="COLOR_GRAYTEXT" value="#CCCCCC" />
<color name="COLOR_GRADLEFT" value="#FFFFFF" />
<color name="COLOR_GRADRIGHT" value="#FFFFFF" />
<color name="COLOR_INTGRADLEFT" value="#FFFFFF" />
<color name="COLOR_INTGRADRIGHT" value="#FFFFFF" />
<color name="COLOR_TRAYGRADLEFT" value="#5B5B5B" />
<color name="COLOR_TRAYGRADRIGHT" value="#5B5B5B" />
<color name="COLOR_HIGHGRADLEFT" value="#5B5B5B" />
<color name="COLOR_HIGHGRADRIGHT" value="#5B5B5B" />
<color name="COLOR_TRAYTEXT" value="#FFFFFF" />
<color name="COLOR_WINDOWFRAME" value="#000000" />
<color name="COLOR_BTNFACE" value="#8c8c8c" />
<color name="COLOR_BTNTEXT" value="#000000" />
<color name="COLOR_SCROLLBAR" value="#5B5B5B" />
<color name="COLOR_HOMETEXT" value="#FFFFFF" />
<color name="COLOR_HOMEHIGHLIGHT" value="#
FFFFFF" />
If u change the "#
FFFFFF" to another code from here:
http://www.colorschemer.com/online.html then resave the xml file with the same name, reload onto Q, select a different HS, then select the HS u want, it would be the color u want it to be. If not, Kayla will do it 4 u, if u want to wait.
