Old 01-31-2007, 01:24 PM   #31 (permalink)
darrink1 is on a distinguished road
Originally Posted by army95cspec View Post
ok i got it ... but i when i use it i can not find the orange file thing i can find it in the normal file explorer... but not in the resco...
you need to tell resco to show hidden system files
then select the "4orangeh" and select "open with" and browse for the other exe file.
darrink1 is offline
Old 01-31-2007, 03:59 PM   #32 (permalink)
yggdrasil is on a distinguished road
Default Made it work. Looks great
Looks pretty cool.
Too bad its not free.
yggdrasil is offline
Old 01-31-2007, 04:16 PM   #33 (permalink)
army95cspec is on a distinguished road
ok thanks for your help i got that part now i need to do that other file but where can i get it
army95cspec is offline
Old 01-31-2007, 04:43 PM   #34 (permalink)
do a web search for facade smartphone.
darrink1 is offline
Old 01-31-2007, 05:12 PM   #35 (permalink)
yea i did that while waiting for a response i did the trial for now and it works great except one icon isnt working that i think should its the task manager... it fails to load application even though thats an app that comes with windows mobile any suggestions? and thank you again for all your help!
Old 02-04-2007, 11:53 AM   #36 (permalink)
spreisigke is on a distinguished road
can someone please post a link to download this, im having trouble finding it. It looks as if the original site doesnt host it anymore? am i wrong>?
spreisigke is offline
Old 02-04-2007, 04:28 PM   #37 (permalink)
8lias is on a distinguished road
same here, couldn't find it.
8lias is offline
Old 02-06-2007, 11:13 AM   #38 (permalink)
For Resco file explorer:
http://www.resco-net.com/smart/downl...eren_s.ARM.CAB
copy the cab file to your phone and use file manager to run it.
For Facade:
http://download.softpedia.com/dl/4b5.../facade100.zip
darrink1 is offline
Old 02-08-2007, 03:44 PM   #39 (permalink)
wadditz88 is on a distinguished road
if you want this homescreen:
get it here:http://www.pinnaclesystems.com/IQPHONE.rar
unrar it and dump it in \Application Data\Home\
you will need to register the orange plugin and buy the facade plugin
change the color scheme to black and the screen to black vista (modded from gadgets black vista screen)
The calander on the home screen is generated by facade as well.
When you cursor down into it, you can scroll down and you can view 30days worth of calander events and click on any event to view its details.
Forgive my ignorance, but when i go to DL the file all i get is a bunch of garbled text, is this correct? any info appreciated thanks.
wadditz88 is offline
Old 02-08-2007, 07:13 PM   #40 (permalink)
its a .RAR file that needs to be unRARed. (search for winRAR)
darrink1 is offline
