Originally Posted by darrink1 You need to use Resco Explorer to properly register the 4orangeh.dll using WM5_REGSVRCE.EXE (make sure both programs are in the same directory location)
You highlight the DLL file (in Resco Explorer) and select "open with" then browse to find the wm5_regsvrce.exe file.
the result is like typing "wm5_regsvrce.exe 4orangeh.dll" on a DOS command line. |
You don't need to go through anything like that anymore. There is a thread further down I started a while ago with a different version of the Orange.dll file I edited. It doesn't need to be manually registered. If you run the cab on your phone, it works....and that's it.
