Old 08-28-2008, 10:58 PM   #11 (permalink)
scratch that
found it here
http://www.smartmodz.com/forum/showthread.php?t=600
Old 08-28-2008, 10:59 PM   #12 (permalink)
brandon.roeder's Avatar
brandon.roeder is on a distinguished road
uuumm....
i would use the advanced search feature here and search for prosper and lcd plugin
even though lcd would be to short it might help with the word plugin...
or you could PM him
Yeah..Lcd is too short. I'll try PMing him.
If you come across the link please post it here
Edit: Thats just the plugin..right?
brandon.roeder is online now
Old 08-28-2008, 10:59 PM   #13 (permalink)
see above post
Old 08-28-2008, 11:04 PM   #14 (permalink)
yeah..thats just the plugin..correct?
I would like the homescreen..with the plugin already edited in.
Old 08-28-2008, 11:04 PM   #15 (permalink)
the lcd plug-in is on Prosper's web site..
potQ9c
Old 08-28-2008, 11:06 PM   #16 (permalink)
oooh i didnt realize the homescreen link was broke
i thought you were missing just the lcd plugin....
bleh....i dont have an original copy...you could pm the original creator
Old 08-28-2008, 11:09 PM   #17 (permalink)
Yea..the link to the homescreen is broken. I have the lcd plugin.
Anyway you could just post the lcd section or somethingof your xml?
I could edit it in.
Old 08-28-2008, 11:10 PM   #18 (permalink)
I could edit it in.
this is all i see under LCD plugin
<!--lcd plugin-->
<plugin clsid="{cef3db66-ad48-46c1-b849-66cf29b5a26d}" height="78" inifile="\Application Data\Home\LCDCarbonFiberTabs\lcd\lcdplug.ini">
<speed fullrefreshwaitms="30000" scrollwaitms="60"/>
<time x="15" y="23"/>
<date x="193" y="25"/>
</plugin>
hope it works
brandon.roeder (08-28-2008)
Old 08-28-2008, 11:19 PM   #19 (permalink)
<!--lcd plugin-->
</plugin>
hope it works
Finally it works!
Thanks so much!
Old 08-28-2008, 11:23 PM   #20 (permalink)
Finally it works!
Thanks so much!
whew
glad you got it to work!
