Old 12-10-2007, 09:00 PM   #1 (permalink)
Shaun_Reid is on a distinguished road
Default I Neeed Help!!
everytime i try and copy or drap the zip files into the home screen folder it doesnt let me...
Shaun_Reid is offline
Old 12-10-2007, 09:21 PM   #2 (permalink)
TreeFrog's Avatar
What zip file? Are you sure your suppose to take the whole file over..
TreeFrog is offline
Old 12-10-2007, 09:27 PM   #3 (permalink)
mike250rs's Avatar
try unziping the files first then transfering them to the Q. Then use file manager on Q to move them to the corect location
mike250rs is online now
Old 12-10-2007, 09:40 PM   #4 (permalink)
this is correct
you can not move files out of a zip file without unzipping the file
draggin from within the file will not work
also make sure its zip file and NOT a cab file
Old 12-10-2007, 11:49 PM   #5 (permalink)
this is correct
OKay i got it thanks
