Old 04-29-2007, 06:58 PM   #1 (permalink)
mrmailer is on a distinguished road
Default how to restrict vertical scroll?
Just wondering how i prevent this .xml from allowing vertical scroll...
Also, why does fgcolor="#000000" not work for the calendar plugin?
mrmailer is offline
Old 04-29-2007, 09:15 PM   #2 (permalink)
the reason it probably scrolls is becuase there is to much going on on the screen that its larger than it can hold so its technically on 2 pages
Old 04-29-2007, 09:17 PM   #3 (permalink)
wow talk about a bunched up xml file...hurt my eyes..lol
try adding the color code to the selected text and unselected text portion of the calendar code...see if that works
Old 04-29-2007, 09:20 PM   #4 (permalink)
It is a hacked IQV2 using orange plugin.
I just wish I could find a simple place to put calendar plugin so that I could see appointments.
mrmailer is offline
Old 04-29-2007, 09:24 PM   #5 (permalink)
can you take a screen shot of the homescreen?
Old 04-29-2007, 09:27 PM   #6 (permalink)
well, now i have the calendar instead of profile, but i want both
IF you can just tell me how to easily, using orange.dll, have calendar and profile plugin right next to each other, my day would be made))
<!-- Calendar Plugin -->
<plugin clsid="{865A354A-4A96-4687-B001-C155DC0DBE76}" name="calendar" height="20" width="113">
<background b-border-width="0">
</background>
<label x="20" y="0" w="250" halign="right" bgcolor="transparent" fgcolor="#000000" font-size="15">
<format state="unselected" font-weight="normal" />
<format state="selected" font-weight="bold"/>
<text><subject/> <time/> <location/></text>
</label>
</plugin>
<!-- Profile Plugin
<plugin clsid="{95976968-45D5-40c9-9779-2B859B1C2FEC}" name="profile" height="20" width="320">
<background>
</background>
<label halign="left" valign="bottom" x="6" y="0" w="320" fgcolor="#000000" font-weight="bold" font-size="15">
<format state="selected" font-weight="bold" fgcolor="#ffffff" font-size="20"/>
<text>Profile: <profile/></text>
</label>
</plugin> -->
mrmailer is offline
Old 04-29-2007, 09:31 PM   #7 (permalink)
i dont use orange.dll unfortunately , but i think it would be better if you had the bluetooth plugin and profile plugin on 1 line since the calendar can be a wide plugin...search the homescreen forum i know people have done this and you can mimick there code...
Old 04-29-2007, 10:01 PM   #8 (permalink)
thanks.
however, it's not designed like that
see?
http://i5.photobucket.com/albums/y17...eenShot1-8.png
mrmailer is offline
Old 04-29-2007, 10:06 PM   #9 (permalink)
oooooh i see...
well...that is a pretty packed screen...what i would recomend is to put the calendar plugin in place of the profile plugin...you can always access the profile by holding down the home button and select the one that you need...not exactly what you are looking for but i dont think you will get what you want with the calendar right next to the profile, it will be wastes since the calendar plugin is long
Old 04-29-2007, 11:47 PM   #10 (permalink)
You'd think it would be that easy.
Please look at attached file.
As SOON as i delete plugin profile section, I cannot use the home screen anymore, as home.exe keeps crashing.
what's the deal?
mrmailer is offline
