Old 05-02-2007, 02:15 PM   #11 (permalink)
dude, check out this post/thread: http://www.everythingq.com/forum/q-h...html#post20837 they seem to have the sms/mms/vm on separate lines..
Old 05-03-2007, 11:04 PM   #12 (permalink)
buckguin is on a distinguished road
For some reason, my computer wont unzip the file.. Have you checked out the XML of it to see whats going on with it??
buckguin is offline
Old 05-04-2007, 08:51 AM   #13 (permalink)
it could be a .rar or even a .cab file.. what is the extension of the file ?
i did not check the .xml myself.
Old 05-05-2007, 01:03 PM   #14 (permalink)
Ok, I got it open.. It looks pretty simple.. It has them just on separate lines with separate x y coordinates compared to the normal ones that only have one set of coordinates.. Im going to have to give this a try.
buckguin is offline
Old 05-06-2007, 12:29 AM   #15 (permalink)
RFI4U's Avatar
RFI4U is on a distinguished road
Send a message via MSN to RFI4U
This format should do what you want.
If you want them to hide when you have no
messages or voice mail just change the "false" to "true"
<plugin clsid="{62E5C279-1E55-4bbb-95DA-D576093C23BE}" name="MessageCount" height="20">
<background>
<format state="selected" bgcolor="COLOR_HOMEHIGHLIGHT"/>
</background>
<label>
<text lang="0x0409">Email <unreadEmail hidezero="false" /></text>
</label>
</plugin>
<background>
</background>
<label>
<text lang="0x0409">Text Messages <unreadMsgs name="SMS" hidezero="false" /></text>
</label>
</plugin>
<background>
</background>
<label>
<text lang="0x0409">MMS <unreadMsgs name="MMS" hidezero="false" />
</label>
</plugin>
<background>
</background>
<label>
<text lang="0x0409">Voicemail <unreadVMail hidezero="false"/></text>
</label>
</plugin>
Hope this helps -
RFI4U is offline
Old 05-07-2007, 09:01 PM   #16 (permalink)
Thanks. I havent had much time mess around with my phone recently but I like this.. I like the idea of hiding them, never even thought of that.. That way I can make the text huge and stick out but it wont get in the way of anything when I dont have mail.. Ill give it a try and let ya know...
buckguin is offline
