Old 05-30-2007, 12:38 AM   #1 (permalink)
williamkidd is on a distinguished road
Need Help How Do You Isnstall Facade???
HOW DO I INSTALL FACADE!!!!!
ive gotten through most of it. BUT... i dont know if i should install it before or when its on my q... and i cant even install it??? i just dont understand?
any help/ sugggestions.
williamkidd is offline
Old 05-30-2007, 08:38 AM   #2 (permalink)
it depends, if it is a .zip file unzip it on the pc with the Q connected and start/execute the Facade.exe.
if it is a .cab file (looks like a zip on the pc so check the extension), copy it to the Q and start/execute the .cab file with the File Manager.
Old 05-30-2007, 12:41 PM   #3 (permalink)
If you downloaded it directly from SBSH, you might have a zip file. Inside the zip file are both an exe installer to install from your PC using ActiveSync and a cab installer to copy directly to your device and launch from there.
-- Motorola Q, WM5, Verizonwireless, U.S.A. --
scottjb is offline
