Old 12-17-2007, 02:33 PM   #21 (permalink)
Originally Posted by LuvrGirl View Post
What does the Orange plug-in do?
it allows multiple plugins next to each other on the same line.. plus it also can put the clock (or any plugin from what i understand) in the icon-bar.
Also, I really like this homescreen and it just gave me an idea... I love my current homescreen but would like to add that Facade plug-in just to show more calendar events... so looking at this it is possible right? Can I just add the facade plug-in calendar portion to my current homescreen? How would I go about doing that?
MaRiA
Facade can be used to display more calendar "events", that is set in the Facade settings, you may have to adjust the screen (images and/or other plugins) so it all fits..
Old 12-17-2007, 02:56 PM   #22 (permalink)
Facade can be used to display more calendar "events", that is set in the Facade settings, you may have to adjust the screen (images and/or other plugins) so it all fits..[/quote]
Yeah, that's exactly what I want - more calendar events displayed on my current homescreen.
So, how would I go about simply adding the additional calendar events feature to my current homescreen?
MaRiA
LuvrGirl is offline
Old 12-17-2007, 03:56 PM   #23 (permalink)
docmac129's Avatar
Purchase facade, (or the Trial period), then load facade onto Q. When that is done, on Q --> Start--> facade settings--> Select Homescreen layout, and adjust the settings. That's it. All of your calendar appts will be added into your homescreen depending how many lines you make the plugin under settings. I usually use ~100-115 so that it shows 3-4 days worth.
Peace
docmac129 is online now
Old 12-17-2007, 04:02 PM   #24 (permalink)
thanks docmac..
Old 12-17-2007, 05:38 PM   #25 (permalink)
docmac129's Avatar
Originally Posted by LAMPRO View Post
Hey any chance to get der to do a no-plugin birfday hs???
love the layout of the rush hour hs, with as much on the hs as possible without plugins..
thanks man, been patient..
Here's one: Der Alta is probably busy w/other requests. Thanks for being patient, as all of the designers here have a busy life also w/ the holidays coming up, and all the requests filtering in (Not to mention our full time jobs)
Just unzip file --> load all 3 files into application data/home. Select black keys under color scheme if u want and u should be all set. NO PLUGINS req.
Peace
The Following 2 Users Say Thank You to docmac129 For This Useful Post:
Englrdr (12-18-2007), LAMPRO (12-18-2007)
Old 12-18-2007, 01:34 AM   #26 (permalink)
LAMPRO is an unknown quantity at this point
any chance of a screenie?
LAMPRO is offline
Old 12-18-2007, 05:54 AM   #27 (permalink)
Docmac129 did quite a nice job on his. If it's not quite right, politely asking for a tweak or two is the way to go. A birthday homescreen isn't really something I'm interested in making.
Plus, I've got a new Facade screen I'm working on, as well as a few other requests.
I'll have to pass on this one.
Der Alta is offline
Old 12-18-2007, 08:20 AM   #28 (permalink)
docmac129's Avatar
Question Screenie
Screenie??? U mean a Full Screen Missed Call Screen? If u like the one that I put into the 1st screen that used facade, then yeah I can put it in, just let me know. Other than that, it would have to wait for a while, cuz I got too many other requests goin.
Peace
The Following User Says Thank You to docmac129 For This Useful Post:
LAMPRO (12-19-2007)
