Old 12-22-2007, 09:04 PM   #1 (permalink)
lostcausenjtown's Avatar
lostcausenjtown is on a distinguished road
Send a message via AIM to lostcausenjtown Send a message via MSN to lostcausenjtown Send a message via Yahoo to lostcausenjtown
Default Homescreen Request-Dallas Cowboys
I have made an image in photoshop and would like a homescreen made out of it. Could you please incorporate the clock in the upper left corner. Thanks in advance.
lostcausenjtown is offline
Old 12-22-2007, 09:15 PM   #2 (permalink)
docmac129's Avatar
Attach the jpg to your next post, and someone will attack it. Also, what, if any plugins u want. Calendar, facade, orange, etc.
Peace
docmac129 is online now
Old 12-23-2007, 10:38 AM   #3 (permalink)
also you should probably make the image larger right now it is sized less than the actual screen size of the Q
make sure its atleast 320x213
Old 12-23-2007, 12:21 PM   #4 (permalink)
Default Ok
I would like the calender pluging in the bar at the bottom and the clock in the upper left corner. The date and the profile pluging could be on the left and right making it a very clean homescreen. As far as the size i think it is already 320x213. It was my first one. That being said it might need some retouching. I will post in in an attachment in a few seconds. Thanks in advance.
Old 12-23-2007, 12:25 PM   #5 (permalink)
your image shows up at 240x161
Old 12-23-2007, 04:20 PM   #6 (permalink)
I changed the attachment in both post so it should be 320x214 now. Thanks for the heads up.
Old 12-23-2007, 09:47 PM   #7 (permalink)
yes now they are thank you
lostcausenjtown (12-23-2007)
Old 12-23-2007, 10:41 PM   #8 (permalink)
docmac129's Avatar
Do u have the Orange plugin on your phone?
If so, the time/date & profile can be on the same horizontal line making it look nicer. If not, then profile has to be on a seperate line. Also, do u want missed calls on homescreen or a seperate Full Screen Missed Call screen, and what about Voice mail on the HS?
Let me know
Peace
The Following User Says Thank You to docmac129 For This Useful Post:
Old 12-23-2007, 11:27 PM   #9 (permalink)
That looks great docmac. Could you put the iconbar on it and have the clock on the iconbar and then put the date and profile plugin where you have the clock and date located now. I do not care about missed calls and voicemails they do not have to be there at all. If you need anything else let me know. Thanks again for the xml coding cause I cannot figure that out at all.
Old 12-23-2007, 11:38 PM   #10 (permalink)
docmac129's Avatar
I can do all of that as long as u have the orange plugin loaded in your q. U need that to have multiple plugins on 1 line ( i.e. time on iconbar line) Should be done tomorrow. Just let me know 'bout orange.
