Old 06-01-2007, 03:23 AM   #1 (permalink)
rohan076 is on a distinguished road
Smile Homescreen question
I like the screens on this website http://www.kooldezine.com/Q.htm, but i wanted to know if there is a way to putting a standard list of icons on the homescreen instead of the recently used programs. I'd like to have the 6 most important programs show up there and nothing else??
rohan076 is offline
Old 06-01-2007, 08:08 AM   #2 (permalink)
yea, you can get rid of the MRU (Most Recently Used) all together and add "links", or to make it even easier buy and install/use Facade...
Old 06-01-2007, 09:10 AM   #3 (permalink)
any help on how to add 'links' would be appreciated, i dont want to clog my phone with 3rd party programs. I guess simply editing the xml file would do the job, but how??
rohan076 is offline
Old 06-01-2007, 09:16 AM   #4 (permalink)
facade is a great program...i would consider it an 'uncloging' program...allows you to add alot of things to your homescreen in such a small space...
but i havent seen just a plugin code for just a launcher (i could be wrong)...but you could try this
http://www.pdagold.com/software/detail.asp?s=388
but if your going to use that id recomend using facade...has much much more to offer
Old 06-01-2007, 09:21 AM   #5 (permalink)
yea, what Scott said... but if i were you i would go for Facade (i am not a paid sponsor, i just happen to really like the plugin), it has more then just the 'static' icons.
Old 06-01-2007, 09:54 AM   #6 (permalink)
Thanks guys, I guess I'll get Facade after all!
rohan076 is offline
Old 06-01-2007, 09:58 AM   #7 (permalink)
no problem, all i can say is give it a spin.. there is a free trial time so you can decide if it's something you like.
good luck.
Old 06-04-2007, 07:41 PM   #8 (permalink)
boricuafemme is on a distinguished road
can u please explain to me what Facade is?
boricuafemme is offline
Old 06-06-2007, 07:22 AM   #9 (permalink)
i can't explain it better then what is on the Facade web site: what is it ?.
