Originally Posted by n99hockey 1. make sure in the homescreen menu that you have backgroud and scheme set to default
2. make sure when you unzip the screen if images are in seperate folders they stay in those seperate folders when you load them in to \application data\home
give those a shot |
The .xml is seperate from the other files in the folder. Do I copy the .xml to application data\home and then copy the entire folder to the same area? I had originally opened the folder and copied all of the individual files into the same location. Should I remove and reload? Thanks for the response, it can be very frustrating at times.
