Old 09-13-2007, 04:26 PM   #1 (permalink)
awseft's Avatar
awseft is on a distinguished road
Question Homescreen help
I've looked at the home screen stickies before posting.
I have a Verizon Moto Q and really like their "VZW Full Layout" because I've gotten use to it. I am yet to find a home screen that I like enough to download.
Seeing as I am use to the one I have, I'd just like to edit it a little. I found the .xml file and tried to delete the ONE line I don't like on there. (The line taht says "News" and "Get Applications". I was unable to save it (overwrite) the current file to use it. I tried using a different name but it didn't show up as an option (even after a restart).
I have used MobileRegistryEditor for some simple hacks I've found here. But this is bugging me.
Any and all help is greatly appreciated.
awseft is offline
Old 09-13-2007, 04:30 PM   #2 (permalink)
copy it elsewhere, for example to the pc and edit there.. also check the properties, the file could be read-only. plus it might be that you have to temporarily have to load another screen because that might conflict.
hope this helps..
Old 09-13-2007, 04:51 PM   #3 (permalink)
awseft's Avatar
I had the wrong Dir. DOH!
awseft is offline
Old 09-13-2007, 05:41 PM   #4 (permalink)
huh ?! how can you have the wrong dir ?
well, you figured it out right ?
