Old 09-17-2007, 08:48 AM   #911 (permalink)
Originally Posted by TreeFrog View Post
Here go....without the .txt
yea, thanks...
Old 09-17-2007, 08:48 AM   #912 (permalink)
Originally Posted by bootheresa View Post
I have the 3 programs. When I save the file it is already named FacadeBlackGlass.home.xml. But when I check the properties it says text file instead of xml file.
if there is already a homescreen with that name, just rename the file (or if you are sure overwrite the one already there.
Old 09-17-2007, 12:12 PM   #913 (permalink)
I think what he's seeing, is that he has "Hide etensions for known file types" clikced in his windows PC options. This hides the .txt in windows, and it'll show up as "FacadeBlackGlass.home.xml" instead of "FacadeBlackGlass.home.xml.txt"
to check this, open explorer (not internet explorer), under "tools", "Folder Options", "view" and see if "Hide etensions for known file types" is checked. If so, uncheck it.
Der Alta is offline
Old 09-17-2007, 12:23 PM   #914 (permalink)
good chance of that indeed... good thinking there.
Old 09-20-2007, 02:27 AM   #915 (permalink)
deejmemixx's Avatar
deejmemixx is on a distinguished road
Some roses my mom sent me from her rose garden. The are beautiful!!! hope you all like the Simplicity i call my HS's lol
deejmemixx is offline
Old 09-20-2007, 08:14 AM   #916 (permalink)
looks good... if you like roses, for obvious reason i am more of a tulip kinda guy :}
Old 09-21-2007, 04:23 AM   #917 (permalink)
PinkMila is on a distinguished road
Default Help.
Hi.
they are very nice.. thank you but i cant get the file on my phone....Can you really tell how i can get the file??? where do i go kooldezine.com on my Motorola Q ?
PinkMila is offline
Old 09-21-2007, 08:17 AM   #918 (permalink)
Originally Posted by PinkMila View Post
Hi.
welcome aboard... not sure which file you mean, to go to Kooldezine : http://www.kooldezine.com/Q.htm
Old 09-22-2007, 08:20 AM   #919 (permalink)
THEFOU is on a distinguished road
Default thanks
Thanks I don't have Fizz Weather, or MadBeetle Clock, but your screens is very cool. How do you like the Fizz Weather app?
here go...requires Facade, Fizz Weather, and MadBeetle Clock. Remove the .txt from the .xml. Hopefully this is how it's done around here!
THEFOU is offline
Old 09-22-2007, 09:15 AM   #920 (permalink)
TreeFrog's Avatar
Like it alot...there are free ones out there but I had the trial, liked how skinny the plug-in was, so had to have it. MadBeetle($4)..same deal. I have RJTime(free) also, just haven't experimented with that one. I've been researching Orange so as to get the Carrier(Home Service) into the Icon bar....have everything I need, just really scared to download. I got way too many apps loaded, so a hard reset would be devastating. Still talking myself into it...as I want to use that room for a bandwidth meter plugin I found.
TreeFrog is offline
