Old 07-26-2007, 07:52 PM   #641 (permalink)
Vertech is on a distinguished road
Originally Posted by qwho View Post
Download here
http://www.mediafire.com/?0mnomzmz33m
Place the folder and xml in your home folder on your phone. You can import the registry entry to make the start bar black. If you already have a black theme on your q, you can copy that and rename it lcars.
the one in this homescreen, its lcars.home.xml.reg
Vertech is offline
Old 07-26-2007, 07:58 PM   #642 (permalink)
emim is on a distinguished road
Has anyone seen a screen for a Lexus? I've found Mercedes but not Lex...
emim is offline
Old 07-26-2007, 08:33 PM   #643 (permalink)
there is one of a Lexus ES350 here...
but i have not seen just a regular 'lexus screen'
emim (07-27-2007)
Old 07-26-2007, 11:29 PM   #644 (permalink)
dilirum's Avatar
dilirum is on a distinguished road
Originally Posted by Vertech View Post
ok anybody know how to add a xml.reg file? I dont know how to add it at all.
A reg file adds information to your registry. I wouldn't add any .reg files to your registry unless you know exactly what it does. A malicious person could make your phone non-functional. Having said that, if you still want to add a reg file to your phone, use Resco reg editor, or PHM (freeware). There's not much in terms of a homescreen or XML that should be done with use of an XML besides maybe changing your softkeys to black.
dilirum is offline
Old 07-27-2007, 12:00 AM   #645 (permalink)
Thats what it does, but how do you add the info? i opened up the file on my Q and nothing happened, Am I to open it up via my comp or on the Q?
Vertech is offline
Old 07-27-2007, 08:27 AM   #646 (permalink)
dilirum's Avatar
if you executed it on your pc it would add the changes to your windows registry on your pc. If you want the info added to your Windows Mobile on your Q, open it on your Q. On mine i can open it with Resco explorer and it pops up askng if i want to add it to the regestry. Not sure if that functionality is built into Windows Mobile (assume so though) or if its beause i installed the Regstry plugin to Resco Explorer. I get the same thing through File Manager on my Q though. Good luck.
dilirum is offline
Old 07-27-2007, 11:02 AM   #647 (permalink)
thank you...
emim is offline
Old 07-31-2007, 02:33 AM   #648 (permalink)
Atomic518 is on a distinguished road
Default Plz Help
Hi, I have a Motorola Q and I just downloaded a .zip home screen file that requires no plug-ins and the file contained 1. the XML file 2. The JPG file 3. The Read me file and I don't have activesync because I use a mac ... can anyone help me so I can install this home screen
Atomic518 is offline
Old 07-31-2007, 08:08 AM   #649 (permalink)
go to the mac section and look for 'missing sync' and that will allow you move files over
-Sent from my Q
Old 07-31-2007, 08:33 AM   #650 (permalink)
like Scott said, Missing Sync or email them to yourself...
