Old 05-06-2007, 02:15 PM   #541 (permalink)
Talon8Ya is on a distinguished road
alright cool keep us posted!
Well I went and figured out that the color settings I was trying to use was what was messing it up.
So if I put in just the blue tooth code with no extra commands it works.
Not ideal though as I wanted it to be blue like the rest of my tex and not white.
Here is the code.
<?xml version="1.0"?>
<home>
<author>Talon</author>
<contacturl>http://www.newbieslinux.com</contacturl>
<title>Drake</title>
<version>1.0</version>
<default target-width="240" target-height="320" font-face="Segoe Condensed" font-size="19" font-weight="normal" padding-left="5" padding-right="5" bgcolor="transparent" fgcolor="#161AFF" padding-top="3" b-border-color="COLOR_HOMERULE" b-border-width="0">
<format state="selected" font-weight="bold" fgcolor="#161AFF"/>
</default>
<background bgimage="Drake.jpg" valign="top"/>
<scheme>
<color name="COLOR_GRADLEFT" value="#FFFFFF"/>
<color name="COLOR_GRADRIGHT" value="#FFFFFF"/>
<color name="COLOR_INTGRADLEFT" value="#FFFFFF"/>
<color name="COLOR_INTGRADRIGHT" value="#CCCCCC"/>
<color name="COLOR_TRAYGRADLEFT" value="#999999" />
<color name="COLOR_HOMEHIGHLIGHT" value="#000000" />
</scheme>
<!--standard missed calls plugin-->
<plugin clsid="{0BA8ABB8-1F1D-417f-88C6-DA8530E2E7A6}" name="missedcalls" height="220">
<background b-border-width="0">
<format state="selected" bgcolor="#000000"/>
</background>
<label halign="center" bgcolor="#000000" fgcolor="#161AFF" font-weight="bold" y="60" w="320" h="220" font-size="32">
<format state="nocall" visible="false"/>
<text lang="0x0409">
Missed calls: <calls/>
</text>
</label>
</plugin>
<plugin clsid="{837FC251-FE69-43ad-84E0-EBCEDEBA0884}" name="Iconbar" height="0">
</background>
<iconbar bgcolor="transparent" fgcolor="#161AFF" y="0" x="0"/>
</plugin>
<!-- Date/Time/Carrier Plugin -->
<plugin file="sysplug.dll" clsid="{E09043DF-510E-4841-B652-388316977A7A}" height="47">
</background>
<label bgcolor="transparent" halign="right" font-weight="normal" y="-5" w="320" font-size="16" fgcolor="#CCCCCC">
<text><carrier/></text>
</label>
<clock>
<date font-weight="bold" fgcolor="#161AFF" font-size="18" valign="top" halign="left" mode="short" y="27" w="320" />
<time font-weight="bold" font-size="35" bgtext="transparent" halign="left" fgcolor="#161AFF" mode="12" y="-5" w="320"/>
</clock>
</plugin>
<!-- Profile Plugin -->
<plugin clsid="{95976968-45D5-40c9-9779-2B859B1C2FEC}" name="profile" height="73">
</background>
<label bgcolor="transparent" font-size="16">
<text lang="0x0409">Profile: <profile/></text>
</label>
</plugin>
<!-- Messages plugin -->
<plugin clsid="{2F930BF0-6FE9-4a53-9E17-88E9247BAB48}" name="SMScount" height="18" width="200">
</background>
<label halign="left" bgcolor="transparent" font-size="16">
<text> Email: <unreadEmail /> SMS: <unreadSMS /> Vmail: <unreadVMail/></text>
</label>
</plugin>
<!-- Calendar Plugin -->
<plugin clsid="{865A354A-4A96-4687-B001-C155DC0DBE76}" name="calendar" height="22" width="170">
</background>
<label w="170" halign="left" bgcolor="transparent" font-size="16">
<text><subject/> <time/> <location/></text>
</label>
</plugin>
<!-- Bluetooth Plugin -->
<plugin clsid="{df648b7e-7645-419d-ba0b-503acea3edfb}">
</plugin>
<!-- MRU -->
<plugin clsid="{79EFB752-CB70-446d-B317-499723482B3D}" name="startmru" height="25">
<mru x="5" highlight="#161AFF" icon-size="16" max-buttons="7" y="0"/>
<appname halign="left" x="185" y="6" font-size="16" fgcolor="#161AFF"/>
</plugin>
</home>
Now I just have to figure out how to get the text to go blue like the rest without corrupting the plugin and then bring the whole set of plugins up one level to keep the theme to one page I will be good. LOL
I am getting there.
At least it is fun.
Talon8Ya is offline
Old 05-22-2007, 04:30 PM   #542 (permalink)
.plaid's Avatar
.plaid is on a distinguished road
Originally Posted by gadget View Post
...You can check them out here:
http://www.kooldezine.com/Q.htm
gadget
Just wanted to join the choir and sing a chorus of "thanks!" I'm currently using the Media Player Theme (since I bought my Q for multimedia, primarily) but have also downloaded the Salt Lake City Temple Theme (I'll probably find a way to display the Newport Beach Temple instead though....)
Best,
.plaid is offline
Old 05-22-2007, 04:50 PM   #543 (permalink)
RFI4U's Avatar
RFI4U is on a distinguished road
Send a message via MSN to RFI4U
I am getting there.
At least it is fun.
Try adding this in your <scheme> tags:
<color name="COLOR_HOMETEXT" value="#161AFF"/>
RFI4U is offline
Old 05-22-2007, 05:08 PM   #544 (permalink)
shaun0207's Avatar
shaun0207 is on a distinguished road
Send a message via MSN to shaun0207 Send a message via Yahoo to shaun0207
Originally Posted by Birdsoft View Post
Now that I have my plugin out I have started to dabble in getting a couple of home screens made that work and look the way I want.. I can see why everyone is so addicted to doing these things.... Heres what I am using right now....
(oh thanks to all who inspired, and for the black key stuff)
Is that the Photo Dialer Plugin your using? How did were you able to change it they way you did?
shaun0207 is offline
Old 05-22-2007, 05:22 PM   #545 (permalink)
Thanks I will try it.
When I used the tags along with the plugin it would corrupt it for some reason.
I will try this and let you know.
Thanks again.
Talon8Ya is offline
Old 05-23-2007, 12:31 PM   #546 (permalink)
King12345's Avatar
King12345 is on a distinguished road
Default Guinness Theme
From a new user...Thanks for all the ideas!
I went with a Guinness theme.
King12345 is offline
Old 05-23-2007, 12:34 PM   #547 (permalink)
Xian is on a distinguished road
Send a message via AIM to Xian Send a message via Yahoo to Xian
ooh ... it's now my mission to make a Captain Morgan one. can't believe i didn't think of it sooner.
Xian is offline
Old 05-24-2007, 05:55 PM   #548 (permalink)
.plaid's Avatar
Plagiarizing heavily on the Motorola Q Home Screen created by gagdet, I offer you my current home screen:
For the three of you who didn't recognize it immediately, this is the official tartan of the state of Washington.
Best,
.plaid is offline
Old 06-08-2007, 10:15 AM   #549 (permalink)
jrstinkfish is on a distinguished road
Just wanted to give thanks for gadget's "Mac 3 with Profile" home screen -- it's exactly what I wanted. I hated the Sprint home screen, and Facade didn't impress me, so this is great.
jrstinkfish is offline
Old 06-09-2007, 02:27 PM   #550 (permalink)
colin292 is on a distinguished road
Thanks, that's awesome.
Here's my take on it:
http://dl3.ohshare.com/v/8672937/iphone.home.xml.html
colin292 is offline
