Old 05-05-2007, 03:04 PM   #531 (permalink)
hookem is on a distinguished road
Originally Posted by gadget View Post
Make sure you copy the files from the zip file to your computer and then copy the files to you Q in the /Application Data/Home folder.
Then you should be able to choose the home screen. Select the Home Screen and then set the Background Image and the Color Scheme to default.
You just made my day!!! THANKS!!!! I was coping just the jpg not the other file!!!! Thanks again!
hookem is offline
Old 05-05-2007, 07:26 PM   #532 (permalink)
JanieceSmith is on a distinguished road
Send a message via MSN to JanieceSmith Send a message via Yahoo to JanieceSmith
Music or Audio Help I am a 2 day old Moto Q owner...
Dear Gadget,
A gentleman in the sprint store told me about your site and I would like to get the 2 page home screen because I hate having so much information on my first screen. How do I begin to download one of your zip files to my phone and install it? Also I am not XML savvy at all so how do I make the change to show my name on the device. I know you have to be quite busy but I would really appreciate the help.
Since there are so few out there, I have created a bunch of Home Screens for the Q if anyone is interested...
You can check them out here:
http://www.kooldezine.com/Q.htm
gadget
JanieceSmith is offline
Old 05-05-2007, 07:28 PM   #533 (permalink)
Music or Audio Louis Vuitton Home Screen
I was also told that you have a louis vuitton home screen but I wasn't able to find it on the kooldezine website. Does that come in the 2 page version as well?
Gadget is still alive and kicking
The problem is that the home screen requests have gotten so out of hand that I have stopped making them.
I have contributed hundreds of home screens to the Q community and I tried to keep up with the requests but it has simply got out of hand.
I get close to 100 requests a month (97 exactly in April) and I simply can't donate that much time. This time of year I am very busy with my business and I have to put food on the table.
I do still try to answer any posts or private messages with questions.
It was a learning experience and a lot of fun but it is now time for me to move on to something profitable.
For those that of you that have contributed to the cause, I do appreciate it very much.
gadget
Old 05-05-2007, 08:04 PM   #534 (permalink)
Talon8Ya is on a distinguished road
Hey gadget thanks for all the great themes.
I have been messing a few of them and learning the xml layouts for Win Mobil 5.0.
I just got my moto q a couple weeks ago I love it.
I use verizon so I have been trying to add the blue tooth plugin into your themes so far I am getting there.
Hopefully I can get some themes done and going I will be able to post them for you all.
Thanks for all the work gadget and everyone.
Talon8Ya is offline
Old 05-05-2007, 09:36 PM   #535 (permalink)
Default I did it...
Gadget, just wanted to let you know I posted before I read your readme file. I downloaded the home screen and made the changes too.... I am so very proud. Thanks you made it easy!!!
Originally Posted by JanieceSmith View Post
Dear Gadget,
Old 05-05-2007, 10:34 PM   #536 (permalink)
Dammit you know I build web pages and do scripting for work sometimes but I cannot get the dam Blue Tooth plugin that comes with Verizon service to work outside of the verizon theme.
I like this modified theme I got from gadget but I cannot figure out what to put in to get the BT plugin to work.
Here is the script minus the blue tooth. Anyone have any ideas as to what I should add to get the BT plugin to work??
<?xml version="1.0"?>
<home>
<author>Talon</author>
<contacturl>http://www.newbieslinux.com</contacturl>
<title>Drake</title>
<version>1.0</version>
<default target-width="240" target-height="320" font-face="Segoe Condensed" font-size="19" font-weight="normal" padding-left="5" padding-right="5" bgcolor="transparent" fgcolor="#161AFF" padding-top="3" b-border-color="COLOR_HOMERULE" b-border-width="0">
<format state="selected" font-weight="bold" fgcolor="#161AFF"/>
</default>
<background bgimage="Drake.jpg" valign="top"/>
<scheme>
<color name="COLOR_GRADLEFT" value="#FFFFFF"/>
<color name="COLOR_GRADRIGHT" value="#FFFFFF"/>
<color name="COLOR_INTGRADLEFT" value="#FFFFFF"/>
<color name="COLOR_INTGRADRIGHT" value="#CCCCCC"/>
<color name="COLOR_TRAYGRADLEFT" value="#999999" />
<color name="COLOR_HOMEHIGHLIGHT" value="#000000" />
</scheme>
<!--standard missed calls plugin-->
<plugin clsid="{0BA8ABB8-1F1D-417f-88C6-DA8530E2E7A6}" name="missedcalls" height="220">
<background b-border-width="0">
<format state="selected" bgcolor="#000000"/>
</background>
<label halign="center" bgcolor="#000000" fgcolor="#161AFF" font-weight="bold" y="60" w="320" h="220" font-size="32">
<format state="nocall" visible="false"/>
<text lang="0x0409">
Missed calls: <calls/>
</text>
</label>
</plugin>
<plugin clsid="{837FC251-FE69-43ad-84E0-EBCEDEBA0884}" name="Iconbar" height="0">
</background>
<iconbar bgcolor="transparent" fgcolor="#161AFF" y="0" x="0"/>
</plugin>
<!-- Date/Time/Carrier Plugin -->
<plugin file="sysplug.dll" clsid="{E09043DF-510E-4841-B652-388316977A7A}" height="47">
</background>
<label bgcolor="transparent" halign="right" font-weight="normal" y="-5" w="320" font-size="16" fgcolor="#CCCCCC">
<text><carrier/></text>
</label>
<clock>
<date font-weight="bold" fgcolor="#161AFF" font-size="18" valign="top" halign="left" mode="short" y="27" w="320" />
<time font-weight="bold" font-size="35" bgtext="transparent" halign="left" fgcolor="#161AFF" mode="12" y="-5" w="320"/>
</clock>
</plugin>
<!-- Profile Plugin -->
<plugin clsid="{95976968-45D5-40c9-9779-2B859B1C2FEC}" name="profile" height="73">
</background>
<label bgcolor="transparent" font-size="16">
<text lang="0x0409">Profile: <profile/></text>
</label>
</plugin>
<!-- Messages plugin -->
<plugin clsid="{2F930BF0-6FE9-4a53-9E17-88E9247BAB48}" name="SMScount" height="18" width="200">
</background>
<label halign="left" bgcolor="transparent" font-size="16">
<text> Email: <unreadEmail /> SMS: <unreadSMS /> Vmail: <unreadVMail/></text>
</label>
</plugin>
<!-- Calendar Plugin -->
<plugin clsid="{865A354A-4A96-4687-B001-C155DC0DBE76}" name="calendar" height="22" width="170">
</background>
<label w="170" halign="left" bgcolor="transparent" font-size="16">
<text><subject/> <time/> <location/></text>
</label>
</plugin>
<!-- MRU -->
<plugin clsid="{79EFB752-CB70-446d-B317-499723482B3D}" name="startmru" height="25">
<mru x="5" highlight="#161AFF" icon-size="16" max-buttons="7" y="0"/>
<appname halign="left" x="185" y="6" font-size="16" fgcolor="#161AFF"/>
</plugin>
</home>
Talon8Ya is offline
Old 05-05-2007, 11:11 PM   #537 (permalink)
you should just be able to copy and paste the bluetooth plugin code from another xml file and it should work...make sure you grab the entire BT code...
Old 05-05-2007, 11:13 PM   #538 (permalink)
if it still doesnt work try this....
http://msdn2.microsoft.com/en-us/library/ms839391.aspx
Old 05-06-2007, 01:43 PM   #539 (permalink)
I had pasted it and not had it show up.
Now this site has tons of info thanks.
I will check it out and see if I can get it to work and post back here to let you know.
Thanks.
Talon8Ya is offline
Old 05-06-2007, 02:01 PM   #540 (permalink)
alright cool keep us posted!
