Old 01-04-2008, 06:48 AM   #1 (permalink)
crashdau's Avatar
crashdau is on a distinguished road
Default Home Screen request for Eko - Red Mesh?
Eko, I have your Black Mesh home screen and really love the simplicity of it. Is it possible for you to make in red and other colors? Right now I would love to have it in red/black to match my Q9m.
As far as plugins I think I have learned enough from this forum to edit the xml's to add/remove the plugins I want to use.
Thanks for considering it,
crashdau is online now
Old 01-04-2008, 07:18 AM   #2 (permalink)
Eko has not been around much, as a matter of fact the last time she was here was on 10-07-2007 (yep.. big brother, or big rb in this case is closely monitoring :}
Old 01-04-2008, 09:57 AM   #3 (permalink)
crashdau's Avatar
A shame she's not around. Hopefully, she'll be back to help out on this one. I just don't have the ability to change that Mesh jpeg. That's all that I really need, multiple colors of that mesh and I make the xml's myself.
Thanks for the info rb.
Old 01-04-2008, 10:01 AM   #4 (permalink)
other creative creators will see this thread and might be able to help you.. it would be great if she -Eko- would be around more/again.
Old 01-05-2008, 02:40 PM   #5 (permalink)
docmac129's Avatar
Default Red Mesh
While Not the same Mesh pattern, here is a version that I created with Ps that has the Red/Black gradient with another mesh version:
And, here is the original Black Mesh, if anyone wants to give it a whirl:
Peace
docmac129 is online now
Old 01-05-2008, 03:25 PM   #6 (permalink)
crashdau's Avatar
Doc, thanks for helping out. Can't see the red one right now on my Q9M but will check it out as soon as Iican get to a pc. Getting a file not found.
Posted on Q9M
Old 01-06-2008, 02:21 PM   #7 (permalink)
crashdau's Avatar
Hey Doc...I downloaded the Red_mesh jpg and changed the the xml I'm using but I get a whitescreen using it. Any ideas?
Old 01-06-2008, 02:23 PM   #8 (permalink)
did you put it in the '\application data\home' folder?
also make sure you typed it right in the xml code
docmac129 (01-06-2008)
Old 01-06-2008, 02:38 PM   #9 (permalink)
docmac129's Avatar
And if that doesn't work, post just that part of your xml so that we can take a look at it to figure it out.
Peace
Old 01-06-2008, 05:01 PM   #10 (permalink)
crashdau's Avatar
Yeah, I put the jpg in the mesh folder where the Black mesh jpg is. I, also, put it in the home folder just in case and it still comes up white. Even tried renaming and re-saving it in Paint Shop Pro.
Here is the XML code I used:
<default target-width="240" target-height="320" font-face="Segoe Condensed" font-size="16" font-weight="normal" bgcolor="transparent" fgcolor="#FF8000">
<format state="selected" font-weight="bold" fgcolor="#FFFFFF"/> <!-- default 000000 -->
</default>
<background bgimage="redmesh.jpg" valign="top" bgcolor="#FFFFFF" bgimage-rotated="redmesh.jpg"/>
