Originally Posted by n99hockey you may or may not need to unlock the phone
have you done any reg edits? if you have then you are fine you cant because you get an access denied error then you have to unlock your phone with AECONFIG which can be found here http://mq.roeiboot.com/apps/ |
thanx, i dunno if i still need to use the AE program but i unlocked it using this site from b4 with my other 2 q's
http://www.qusers.com/forum/viewtopic.php?t=523
as far as the cab files, ill b patient cuz ima definately get it eventually, i really dont want u 2 change anything from the HS cuz its perfect. the files dont even look like cab files when i go to unzip them and load em up, i dunno whats up at all
