I'll pm u L8r with the two files needed. I don't have them loaded on my laptop, only my desktop. (This is if u don't get it loaded from the cab file, which I found
here. Unfortunately, this is another cab file, but it is supposed to contain both files that are needed in 1 cab) As far as having to unlock your Q, b4 u load on orange, that is something that I will have to leave up to Rudeboy or n99 (Both SuperMods). They would know this. Mine is unlocked for apps, but I don't know if this is a requirement to load Orange.
Just b patient, 1 of them should be around soon. If not u will have it tonight.
Also, if u just cant get it running by tonight, I could modify this HS so it doesn't need Orange, but it would take more time than I got right now.
As far as the blacksoft keys zip, i just tried downloading it and there is a file in it called blacksoft.sheme.xml that u just need to add to application data>home on your q.
Peace
