Old 06-06-2008, 11:43 AM   #1 (permalink)
omg its nate's Avatar
omg its nate is on a distinguished road
Default Home screen Request "6.1 Theme"
I would like something like this on my WM 6 Phone...
Then where it says getting started - Just the 5 or whatever small programs there with display name on the right.
Maybe with this wall...
http://i54.photobucket.com/albums/g9..._1920x1200.png
And green Start Menu bars?
omg its nate is offline
Old 06-06-2008, 11:54 AM   #2 (permalink)
crazykay's Avatar
crazykay is on a distinguished road
Send a message via Yahoo to crazykay
You should be able to get rid of the getting started section yourself. Just go down to the Getting started tab and go to where it says Add/Remove Getting started. As far as the programs your wanting someone will have to study the xml and get back with you. Might take a while. You might be able to do this yourself with the Chome Configurator but im not sure since I dont have that program or 6.1 on my q9c yet. You can also edit that image to the 320 x 240 pixels then copy it to application data/ home and just select it as your background image from your settings then set your color scheme to Green or Default which should give you the Green bars
crazykay is offline
Old 06-06-2008, 11:58 AM   #3 (permalink)
I have windows mobile 6. I just wanted this theme created for my phone.
Old 06-06-2008, 12:13 PM   #4 (permalink)
crazykay's Avatar
Oh i SEE well good luck!! I thought you had 6.1. my fault. Guess I should read better next time..lol *duh*
crazykay is offline
Old 06-06-2008, 12:18 PM   #5 (permalink)
PacoJr67's Avatar
have you checked out eko's flip design? it's pretty close
PacoJr67 is offline
Old 06-06-2008, 01:41 PM   #6 (permalink)
mike250rs's Avatar
why settle for an outdated 6.1 theme when you can have a WM7
couldn't resist...
mike250rs is online now
Old 06-06-2008, 01:51 PM   #7 (permalink)
couldn't resist...
i hear that!!!
wm6.1 is soooo yesterday
Old 06-06-2008, 02:34 PM   #8 (permalink)
PacoJr67's Avatar
sooo tuesday actually....
PacoJr67 is offline
Old 06-06-2008, 02:37 PM   #9 (permalink)
crazykay's Avatar
OOOOOOO Paco even updated his Avatar to 6.1..!! Nice Job!!
crazykay is offline
Old 06-06-2008, 02:53 PM   #10 (permalink)
it's seriously outdated already :}
