Old 09-29-2007, 01:34 PM   #1 (permalink)
no25 is on a distinguished road
Default Home Screen Programs
What home screen program do you use and how good does it work.
no25 is offline
Old 09-29-2007, 02:20 PM   #2 (permalink)
they arent that great
but if i had to pick one ir would be madeetle
www.madbeetle.com
-Sent from my Q
Old 09-29-2007, 02:51 PM   #3 (permalink)
Notepad works great.. DOS edit even better :}
posted on the Q.
Old 09-29-2007, 04:50 PM   #4 (permalink)
posted on the Q.
that is what i prefer to do HS in
notepad
Old 10-01-2007, 06:22 AM   #5 (permalink)
I also use Notepad. I find that the homescreen programs "get it close" but the really fine tweaks need to be done in notepad. Little Nudges and fine tuning just can't be done in most of those programs.
Der Alta is offline
Old 10-01-2007, 07:16 AM   #6 (permalink)
totally agree.. it is the old cliche What You See Is What You Hope To Get :}
