Old 05-30-2007, 09:52 AM   #1 (permalink)
Cindi is on a distinguished road
Send a message via AIM to Cindi
Default Home Screen Preview?
When editing a home screen, is there any program that will let you preview what it will look like, versus actually transferring it to the phone and installing it, and THEN seeing what it looks like? I am nervous but willing to try making my own but I foresee having to install/uninstall it a lot until I get it right. I have it all sketched out how I want it, I just have to bite the bullet and try it. Many years ago I worked with a scientific publishing program called TeX which seems similar to the xml, but there was a way to 'run' it and see the final version, so I could make corrections as needed along the way. Just wondering if there's something like that for this.
Cindi
Cindi is offline
Old 05-30-2007, 10:04 AM   #2 (permalink)
i use this
http://www.madbeetle.com/HomeScreenBuilder.html
i create it on the PC and then put it on the Q and rearrange it in xml after i see what needs tweaking....cuts down on the back and forth....
give it a shot
Tony Bag o Donuts (12-04-2007)
Old 05-30-2007, 10:08 AM   #3 (permalink)
i use this
give it a shot
Scott! You are my hero! Thank you so much, I'll try it tonight.
Cindi is offline
Old 05-30-2007, 10:12 AM   #4 (permalink)
great!!
now i warn you it doesn always look exactly the same on the Q so you have to do a little bit of xml coding but nothing much...and if you get stuck just post what you need help with on the board and we can figure it out!
happy creating!
Old 05-30-2007, 11:05 AM   #5 (permalink)
Smile
i use this
give it a shot
ahaa.. and here i was thinking you were a hard code xml'er like myself :}
Old 05-30-2007, 11:16 AM   #6 (permalink)
HAHAHA i just found this a little while ago...saves my eyes from all that code!
but i do have to go back in to the code to fix things...for some reason the orientation gets messed up and tranparent doesnt work so i have to make that...but hell cuts down on time...
but it doesnt work with facade and fizz so that stuff you have to know what your doing...
Old 05-30-2007, 01:07 PM   #7 (permalink)
Pony99CA's Avatar
Default Home Screen Editors
Here's my current list of Home screen editors. Note that while they can simplify the task of making basic Home screens, they probably won't be able to help with fancier Home screens that use non-standard plug-ins.
  1. MadBeetle Home Screen Builder -- Runs on your PC (free).
  2. Omega One 1-HomeEdit -- Runs on your Q.
  3. Ruttensoft Homescreen Designer -- Runs on your PC.
  4. V2R Home Screen Editor -- Runs on your Q.
Silicon Valley Pocket PC
http://www.svpocketpc.com
Pony99CA is offline
Old 07-16-2007, 01:43 AM   #8 (permalink)
meika79's Avatar
meika79 is on a distinguished road
Send a message via AIM to meika79 Send a message via Yahoo to meika79
UMMM Ok is it just me or is the Ruttensoft Homescreen Designer not able to download, from anywhere. I've done searches and all that and they all lead me back to that damn page where I can't do anything .
meika79 is offline
Old 07-16-2007, 04:39 AM   #9 (permalink)
Pony99CA's Avatar
Default Just You
I can't say whether it's just you, but I can download it.
Click on the Smartphone.net link on the page and you'll see a Download button. (Clicking the Handango button probably does the same thing.)
Steve
Pony99CA is offline
