Old 10-16-2007, 10:40 PM   #11 (permalink)
Originally Posted by algorhythm View Post
Yep, that screen exactly.
most likely it is the very first plug-in in the .xml.. does it point to a image ?
Old 10-16-2007, 10:46 PM   #12 (permalink)
algorhythm is on a distinguished road
Yep it does.
It does say this though:
RJTime Plugin: This runs the large clock on the first page Note: if you want to retain the ability to run an app (like task manager) from the first page (fish) you need to add this code to the space under "background":
<action target="\Windows\Start Menu\System Tools\Task Manager.lnk"/>
-->f(clean);
algorhythm is offline
Old 10-16-2007, 10:53 PM   #13 (permalink)
the homescreen is a cab file so i cant tell
but from the looks of it the only way you can use it is if you press down to initiate the homescreen
Old 10-16-2007, 10:58 PM   #14 (permalink)
too tired to install it now <yaaawn>...
if Prosper hasn't jumped on this by the time i am on-line in the morning i will check it out.
Old 10-16-2007, 11:03 PM   #15 (permalink)
Don't go crazy, I'm pretty sure it's just a picture. I can hit up in the main screen and go back to the "Press down to unlock" screen.
Old 10-16-2007, 11:05 PM   #16 (permalink)
pretty much thats what it is going to be
only way to use it is pressing down
