Old 05-03-2007, 10:34 AM   #11 (permalink)
what is is that you don't get/understand ?
Old 05-03-2007, 10:44 AM   #12 (permalink)
primetimw6 is on a distinguished road
How to change a jpg file or extension ..... I guess I just do not get it. If I could just get the screen back to the Red Sox one I will have wasteed $ on facade and Fizz but oh well, I just want my phone back
primetimw6 is offline
Old 05-03-2007, 10:51 AM   #13 (permalink)
The red sox one I was using is the 2nd one down on the right
http://www.ekopapers.com/al.htm
Old 05-03-2007, 10:55 AM   #14 (permalink)
to use any of the home screens on your Q you goto Start > Home Screen and then you select the home screen you want, for most downloaded home screens you have to set both the Color scheme and Background image to default.
this hopefully helps you in getting things back to how you want them..
Old 05-03-2007, 10:59 AM   #15 (permalink)
Even when I do that it does not load the red sox screen correctly, it might have to do with facade I think
I really hate being this stupid
Old 05-03-2007, 01:16 PM   #16 (permalink)
hmz, the (as far as i can see) Red Sox home screen is not using Facade so i wonder why it would have any effect at all on it. are you able to load other home screens (default ones) without issues ?
no you are not stupid.. stupid would be not asking questions.
Old 05-03-2007, 01:52 PM   #17 (permalink)
Csquared is on a distinguished road
I could be wrong on this but I think when I loaded Facade the first time it took my current Home screen and added Facade to it and renamed it. Is it possible you have 2 Red Sox home screens, one with Facade and another without.
Csquared is offline
Old 05-03-2007, 02:28 PM   #18 (permalink)
good point Csquared... i forgot Facade did that.
Old 05-03-2007, 03:22 PM   #19 (permalink)
Ok so I went into Home Screen and changed it to the windows Default....on my home screen it is the windows default but it is not all on one screen, I have to scroll down to see say, my email count. So then I go into the facade settings, when I select Windows Default in there it says "This home screen does not currently include Facade. Would you like Facade added to the layout?" All I can say is Yes or no, if I say no it just stays on that screen.
Old 05-03-2007, 03:23 PM   #20 (permalink)
I think that might be true....but that still does not solve my issue of added Fizz to the red sox one. I might just go in and delete the face and red sox ones then try again, but I still need help to get Fizz weather
