Old 06-04-2008, 08:16 PM   #1 (permalink)
fuller45 is on a distinguished road
Default Home screen ...a littlle help...
Well I have a homescreen XML and everytime I alter anything in the XML file on notepad and move it to /App/Home directory on my phone, and goto Settings>Home Screen, it does not show up as an available homescreen...
I am trying to add some plugins to a homescreen I have but when I finish the code then put it on my phone, it doesn't show up as an avaiable homescreen..
Any help?
Ty
~Fuller45
fuller45 is offline
Old 06-04-2008, 08:25 PM   #2 (permalink)
kaylabeers's Avatar
kaylabeers is on a distinguished road
Something is wrong with the coding...A plug-in might be another or something like that. You should post your code up.
kaylabeers is offline
Old 06-04-2008, 08:52 PM   #3 (permalink)
kayla is right...
it could be something as stupid as missing a ' or a /
Old 06-04-2008, 09:06 PM   #4 (permalink)
double click it on the pc and it will open (in your default internet browser) it will more or less tell you where the error is..
also verify that the file name is xxxxx.home.xml
potQ.
Old 06-05-2008, 01:09 PM   #5 (permalink)
potQ.
Named correctly.
I found the prolem, all fixed Thanks guys
~Fuller45
fuller45 is offline
Old 06-05-2008, 01:10 PM   #6 (permalink)
Originally Posted by fuller45 View Post
Named correctly.
what was the problem?
Old 06-05-2008, 01:14 PM   #7 (permalink)
I was missing the end of a plug-in somehow, my oops Must've deleted it by accident somehow
~Fuller45
fuller45 is offline
Old 06-05-2008, 01:18 PM   #8 (permalink)
that happens...glad you were able to figure it out!!
Old 06-05-2008, 01:24 PM   #9 (permalink)
yep... coolio.
