Old 10-02-2007, 03:08 PM   #21 (permalink)
Originally Posted by blueonblackstrat View Post
If it were as easy as that, I would have had it an hour ago
well excuse me for trying to help you but you dont exactly have a way with explaining what you are doing!
you said you put it in that folder (\application data\home) and then opened it and a program opened
now to ME i thought you just clicked on the file you loaded
so maybe you can try to explain what you are doing
what file did you download?
where did you download it?
was it a zip file or a cab file (make sure you check the extension of the file since the icons on the PC are the same)
Old 10-02-2007, 03:23 PM   #22 (permalink)
Banned
blueonblackstrat is on a distinguished road
It was a zipped file...
I put it from the computer to my device after I unzipped in Winrar. Until that point, when I tried to do anything it would show me the program...as it was written, by the author. etc etc...
Now that I've unzipped everything, and sent it to where it goes in my phone... it looks nothing like what the picture showed on the picture in the thread I saw.. it would seem that I have everything where it goes now.
blueonblackstrat is offline
Old 10-02-2007, 03:28 PM   #23 (permalink)
Banned
Old 10-02-2007, 03:47 PM   #24 (permalink)
again, where did you get this screen?
did say you needed any other plugins? (probably why it doesnt look right)
maybe RJShortcut or Orange.dll
Old 10-02-2007, 04:16 PM   #25 (permalink)
Banned
On this very forum.. Home screens and wallpapers.... the thread was began by Der Alta
Post number 49.
Old 10-02-2007, 04:20 PM   #26 (permalink)
Post number 49.
can you post the link
Der Altas Homescreen Thread's post #49 is a message posted by TarheelsRule!
Old 10-02-2007, 04:21 PM   #27 (permalink)
yep, right out of the Homescreen collection thread, here, doesn't mention any plugins...
Old 10-02-2007, 04:31 PM   #28 (permalink)
thanks for the link RB
yea doesnt appear to need any plugins
you should just load the image and xml file to the \application data\home folder
also you should not that in the homescreen settings on the device
(start --settings-- homescreen) the background image should be set to default and NOT the image thats loaded
Old 10-02-2007, 04:34 PM   #29 (permalink)
thanks for the link RB *SNIP*
you bet'cha... i kinda saw your heart-rate go up to dangerous levels so i decided to jump in :}
Old 10-02-2007, 04:37 PM   #30 (permalink)
lol
im as cool as the other side of the pillow my friend
