Old 10-02-2007, 11:04 AM   #11 (permalink)
Banned
blueonblackstrat is on a distinguished road
yeah... I would imagine to get it to the phone, I have to do it through the same process I used to download the crank ringtone..
blueonblackstrat is offline
Old 10-02-2007, 11:06 AM   #12 (permalink)
BlueonBlack, where are you trying to download a homescreen from? Everythingq.com or a Microsoft site? And where are you seeing the 4 tabs? On your computer, the website, this website, your Q?
Der Alta is offline
Old 10-02-2007, 11:06 AM   #13 (permalink)
all you have to do is copy the xml file and jpeg file to the \application data\home folder on the device
no programs to install...
if you found one in a cab file then you need to move the entire cab file to the Q and then go to file manager and click the file to install it
Old 10-02-2007, 11:20 AM   #14 (permalink)
Banned
It's on the home screen thread here... started by rueboy... #49 to be specific... Now I didn't have my phone hooked up at this point, I just put it into my document folder on the puter... perhaps I'll try again to see if I can get it going with the phone plugged in.
Old 10-02-2007, 11:23 AM   #15 (permalink)
it's rudeboy... and yes, those files go on the Q, in the \Application Data\Home folder.
Old 10-02-2007, 02:15 PM   #16 (permalink)
Banned
well, I've found a way to get it to the phone, put it in the home folder in the application folder, when I open it, it shows me the program and nothing else...
Old 10-02-2007, 02:27 PM   #17 (permalink)
the program?
what program are you talking about
have you read the FAQ section on how to install a homescreen?
Old 10-02-2007, 02:44 PM   #18 (permalink)
Banned
Yes I've read the tutorial put on here on how to put do it... That's how I figured out to put it into the applications/home file. So it made it there... but when I open it, it shows the program... as it is written...
Old 10-02-2007, 02:52 PM   #19 (permalink)
you have to go to
start
settings
homescreen and then pick the screen you just copied
Old 10-02-2007, 03:02 PM   #20 (permalink)
Banned
If it were as easy as that, I would have had it an hour ago
