Old 04-27-2008, 12:14 PM   #1 (permalink)
Idntknw is on a distinguished road
Default Highlight transparent?...
Is there a way to remove the black bar when you highlight?...
Thanks...
Idntknw is offline
Old 04-27-2008, 12:45 PM   #2 (permalink)
docmac129's Avatar
what r u highlighting? Facade?
docmac129 is offline
Old 04-27-2008, 01:03 PM   #3 (permalink)
Sorry...guess I didn't explain correctly...
Whenever I select the items on my home screen there is that black bar on whatever I select...
Is there a way to not have the black bar when I select items?....
Idntknw is offline
Old 04-27-2008, 01:58 PM   #4 (permalink)
docmac129's Avatar
Wasn't your fault, I was on my q which couldn't c the picture u were talking about. Yes, there is a way to get rid of that black bar. Can u upload the xml file to your next post (save it as a txt file instead of xml) & I will highlight the area that needs to be changed, or I could do it for u.
Peace
Old 04-27-2008, 02:07 PM   #5 (permalink)
Peace
Sure...
If you dont mind you can show me were to edit it...
Thanks...
Idntknw is offline
Old 04-27-2008, 03:02 PM   #6 (permalink)
Thanks docmac129...it worked...
But what happened to your post?
Idntknw is offline
Old 04-27-2008, 03:08 PM   #7 (permalink)
docmac129's Avatar
Sorry, I deleted it b/c I didn't want to confuse u. It sounded a little confusing to me, so I figured that I would just make the changes for u (which would have taken alot less time on my part than typing out the exact spots to make the change). However, I know that it wouldn't allow u to learn how to make the changes for yourself. And as a side not, my computer crashed right in the middle of doing that & trying to fix a few other members xmls at the same time. Multitasking on my current filled to capacity computer I c is a No No. Time to buy new computer. We can still fix the few problem areas that u r having. Let me take a look at the xml once more.
Old 04-27-2008, 03:22 PM   #8 (permalink)
Not a problem...
Heres what I got....
Idntknw is offline
Old 04-27-2008, 03:23 PM   #9 (permalink)
docmac129's Avatar
To fix the few areas left try this: I made the changes to everywhere I saw I could, then I loaded to my phone and nothing was highlighted with a black bar like it use to be. Give it a shot, just remember to change this txt file, back to home.xml and then reload onto Q. Also, load another HS, then this one to c the changes. Hope it works for u.
Old 04-27-2008, 08:08 PM   #10 (permalink)
Thanks...it worked!...
Idntknw is offline
