Originally Posted by scottjb If you're only using the calendar tab, why even use the tabs? You can eliminate the tab plug-in and just display the calendar plug-in. That also eliminates the need for Orange on your home screen unless you want to put something next to the calendar entries.  Hmm... maybe a few more days of work are needed. ;) |
Tonight im going to work on it a little more. What im trying to do is get just the tab, no schedule below it, so that way you select the tab and that takes you to your calendar, makes the homescreen a little cleaner and cooler lookin, i think, now if i could only figure out my ti 84 calculator, hmmm maybe find a way to connect the Q..hehehe
