Old 12-19-2007, 01:47 PM   #1 (permalink)
lostcausenjtown's Avatar
lostcausenjtown is on a distinguished road
Send a message via AIM to lostcausenjtown Send a message via MSN to lostcausenjtown Send a message via Yahoo to lostcausenjtown
Default Help with my first homescreen
Hi, I need help with my first homescreen. I have no xml knowledge and very little know-how on photo editing. I created this screen using Ruttensoft software. I need to get the time and date in the upper left corner if at all possible. Also, could someone suggest and maybe add some colors to make the softkeys look better. Feel free to play around with it. The file should be in the zip folder below. I hope that screenshot I took works. Thanks in advance.
Last edited by lostcausenjtown; 12-19-2007 at 02:10 PM. Reason: Have screenshot so you can see it now
lostcausenjtown is offline
Old 12-19-2007, 01:51 PM   #2 (permalink)
did you read the tutorials listed in this post ? quite a few members here start of by using Madbeetle's software to create screens.. (i use Notepad.exe myself so :}
Old 12-19-2007, 01:53 PM   #3 (permalink)
Thanks for the link
Old 12-19-2007, 01:55 PM   #4 (permalink)
i can't seem to open the link that you gave. Any suggestions on the homescreen though. I would like to see what people think it being my first and all.
Old 12-19-2007, 01:58 PM   #5 (permalink)
i fixed the link in my previous post....
lostcausenjtown (12-19-2007)
