Old 10-09-2007, 09:30 AM   #1 (permalink)
deejmemixx's Avatar
deejmemixx is on a distinguished road
Default help with editing after making
Ok i am sure you can tell that i use mad beetles program to help me along with the hs making. I just need some detailed..and i repeat detail instructions of how to edit after initially making them. I would like to change the sms/txt and add vmail but with icons (like the new pepsi one), i know there are guides on this and tutorials...but they dont seem to cut it for me to get it down pat. For i have tried and fail..also i have tried the CAB making progy but it makes no sense to me either...so is there another way to do this? Please help :P
thanks in advanced
deejmemixx is offline
Old 10-09-2007, 10:30 AM   #2 (permalink)
thanks in advanced
did you read the tutorials i suggest in this post ?
deejmemixx (10-09-2007)
Old 10-09-2007, 01:38 PM   #3 (permalink)
deejmemixx's Avatar
i sure did buddy lol, just read them again it is still not making sense to me . I really just want to know how to do the icons and make the email/sms/txt all seperated from each other. I know there was a section..but the xml get confusing to me trying to read..maybe going that far is something i will not be able to do...any other thoughts??
but i am gonna try to do a missed call screen and see if i can get that done right..
also, when doing the xml and what not if i zip the xml and the picture together do i have to make a cab file?
Old 10-09-2007, 03:46 PM   #4 (permalink)
another thought would be to download a home screen that has them separated as you want them and look through the .xml..
that's easy.. you should be able to pull it off.
no, you don't have to make a .cab, as a matter of fact i never do :}
Old 10-09-2007, 05:00 PM   #5 (permalink)
Take a look at this home screen, for a missed call screen, and a set-up where the email/txt/sms is on one line.
"Right Click" and "Save As"
and then take a look at this one to see the email/txt/sms in a stacked format.
Both fairly simple screens, and easy to decipher. If you have any questions, feel free to PM me, or post it here.
Der Alta is offline
Old 10-09-2007, 06:06 PM   #6 (permalink)
deejmemixx's Avatar
hmm u must have esp cause i actually was gonna look at the target one after my sons confrenses tonight and see. thanks you!!!!
hmm...been awile since had loaded and my phone is dead now..does the target one let you choose each choice seperatly?? or all highlite at once??
Old 10-09-2007, 06:21 PM   #7 (permalink)
They all highlight at once. You can easily seperate them, but they all go to the same place.
Der Alta is offline
Old 10-09-2007, 07:14 PM   #8 (permalink)
deejmemixx's Avatar
haha ok sorry..but i have to ask.. you say easily seperate them..but how easy??? (or can u explain how plz)
Old 10-09-2007, 07:31 PM   #9 (permalink)
This is from the HomerX screen:
<!-- Messaging Plugin -->
<plugin clsid="{2F930BF0-6FE9-4a53-9E17-88E9247BAB48}" name="SMScount" height="20">
<background b-border-width="0">
</background>
<label halign="right" h="18" x="0" y="-2" w="320" font-size="16" padding-right="0">
<text> Email / Texts: <unreadEmail/> SMS: <unreadSMS/> Voicemail: <unreadVMail/></text>
</label>
</plugin>
This gives the result of
Email / Texts: 0 SMS: 0 Voicemail: 0
Changing it to
</background>
<text> Email / Texts: <unreadEmail/></text>
</label>
</plugin>
Results in
Email / Texts: 0
Now adding a second <label> section like this:
<plugin clsid="{2F930BF0-6FE9-4a53-9E17-88E9247BAB48}" name="SMScount" height="40">
</background>
</label>
<label halign="right" h="18" x="0" y="18" w="320" font-size="16" padding-right="0">
<text> SMS: <unreadSMS/></text>
</label>
</plugin>
Will results in this:
Email / Texts: 0
SMS: 0
Der Alta is offline
