Old 12-14-2007, 01:25 PM   #11 (permalink)
OK, here's what I've got.
"Right Click" and "Save as" to your desktop.
Drag the two files and the folder out of the zip file, and all three to your Q (via Active Sync) to "Application Data/home"
It'll copy 8 files in total.
craiggiarc.home.xml
/craiggiarc/task_active.jpg
/craiggiarc/task_inactive.jpg
/craiggiarc/cal_active.jpg
/craiggiarc/cal_inactive.jpg
/craiggiarc/launch_active.jpg
/craiggiarc/launch_inactive.jpg
You should now be able to go into your settings/homescreen options and select "CraigGiarc - OSU" as your home screen.
Take a screenshot and post it up for me. I'll be able to tweak things when I see it.
Keep in mind, the facade buttons are hidden until you click move to them.
Hope this works, as I'm flying blind on this layout.
Der Alta is offline
craiggiarc (12-14-2007)
Old 12-14-2007, 01:50 PM   #12 (permalink)
craiggiarc's Avatar
craiggiarc is on a distinguished road
This is already looking great, see the attached screen shots, my comments would be:-
1. The date and time probably need to be the same colour as the Carrier Text so that they show up more and probably need to go up a pixel!
2. The message section requires a little widening as when it's highlighted it expands beyond the image.
3. This may be a Facade setting rather than a homescreen setting but is there a way to stop the Facade stuff scrolling off of the bottom of the screen as when that happens all of the other stuff becomes out of alignment.
Thank you so much for your work on this so far.
Craig
It's good to be (Lime) Green.
Visit my work friendly site www.namemysex.co.uk
craiggiarc is offline
Old 12-14-2007, 02:23 PM   #13 (permalink)
OK, I fixed those three issues, and hopefully that should do it. It's on the same link as above, and you can jump through the same hoops to download it and test it out.
Der Alta is offline
Old 12-14-2007, 03:16 PM   #14 (permalink)
craiggiarc's Avatar
That is excellent Der Alta, or should that be just Der? I've "Thanked" you as many times as I can on this topic too.
The only change I made was in Facade to the 'Height' setting and now it doesn't scoll off of the bottom of the screen.
This will now be my homescreen until OSU when a national title, e.g. a very long time!
