Old 04-17-2007, 09:34 PM   #1 (permalink)
Poorman1700 is on a distinguished road
Default Help on some Homescreen cust!!
basically im trying to make it so the hot buttons "start" and "contacts" do not have a background along with those the very top bar with your signal and bat life i want them to use the home screen image as its background instead of that blue, grey whatever
thanks,
Poorman1700 is offline
Old 04-18-2007, 09:17 AM   #2 (permalink)
the top bar can be done by editing the xml text to say 'transparent' where it indicates a color...as for the start and contacts button i konw you can change there color but not sure if you can make them transparent...
Old 04-18-2007, 11:02 PM   #3 (permalink)
and how do you do that change the color of the start and contacts bar???
