Old 09-08-2007, 07:25 PM   #1 (permalink)
freemouse is on a distinguished road
Default Help me get rid of the white line please!
I got this nice pic of pink dogwoods, and i am using eko's fss xml for the text, but i cant figure out this icky white bar? any help?
freemouse is offline
Old 09-08-2007, 07:28 PM   #2 (permalink)
Prosper's Avatar
Define a background image that is has 320 width and 213 height.
Prosper is offline
Old 09-08-2007, 10:22 PM   #3 (permalink)
I tried that but it does not change that white bar on the mru list. it doesnt matter either what color scheme i use as it will not change the white on the mru list.
Old 09-09-2007, 08:06 AM   #4 (permalink)
Can you post just the image for us? It would appear that the image is not the proper size, in which case you'd need to edit it with Photoshop or equivalent to make the image the proper size.
Der Alta is offline
Old 09-09-2007, 08:18 AM   #5 (permalink)
ducs9999's Avatar
ducs9999 is on a distinguished road
Usually when this happen, it is because you've changed the background image directly in the home screen on the Q. If you want to make that work, you will need to change the background image in the xml directly and put back 'Default' in the background image.
Change the following line in your xml:
<background bgimage="xxxxxx.jpg" valign="top"/>
Hope this will help.
ducs9999 is offline
Old 09-09-2007, 08:49 AM   #6 (permalink)
I changed the xml to what ducs suggested but no change to the results. Here is the picture I am using, I did change it to 320x240 before moving it to Q. thanks for trying to help me!
Old 09-09-2007, 08:53 AM   #7 (permalink)
ducs9999's Avatar
Have you put back on the Q the background image to 'Default'?
ducs9999 is offline
The Following User Says Thank You to ducs9999 For This Useful Post:
freemouse (09-09-2007)
Old 09-09-2007, 08:54 AM   #8 (permalink)
Prosper's Avatar
As said before, try size 320x213. That's the actual screen size that is left after substracting 27 px for the softkeys.
Prosper is offline
Old 09-09-2007, 09:11 AM   #9 (permalink)
it might just be the background color selected in the scheme..
Old 09-09-2007, 09:17 AM   #10 (permalink)
ducs9999's Avatar
I just did a quick test, as Prosper said, you will need to bring back the image size to 320*213 but you will also need to remove the default value on your Q in the Setting/Home screen <Background image> to Default, because if you don't do that, the white bar will stay.
ducs9999 is offline
