Old 05-02-2007, 11:40 AM   #1 (permalink)
m_kranzler11 is on a distinguished road
Default Help Me!
So I installed the myiphone theme, and everything was working fine but then I installed the black soft keys color scheme, and after a reboot my phone's homescreen won't load! It loads the start and contacts bar, and if I try to click start nothing happens, so I cant' change my homescreen to anything else. I tried uninstalling the black soft keys scheme, but it still doesn't load my homescreen. Is there any way to change the homescreen through my computer or any thing else I can do? I don't want to have to do a hard reset. Please can someone help me!
m_kranzler11 is offline
Old 05-02-2007, 11:44 AM   #2 (permalink)
You can try connecting to your PC and deleting/moving/renaming the offending home screen xml file via ActiveSync. Then reset your Q and it should start up with no home screen. Then try Start, Settings, Home Screen and see if you can select a valid home screen.
scottjb is offline
Old 05-02-2007, 11:45 AM   #3 (permalink)
there isnt a way to change the homescreen through the PC...but if your able to get to settings and try to uninstall the black key software you should be able to go in to the homescreen menu and change the screen OR put the color scheme back to default...
Old 05-02-2007, 11:47 AM   #4 (permalink)
The only way I was able to uninstall the black scheme was through Windows Mobile Device Center. I can't get to the settings menu.
Old 05-02-2007, 11:52 AM   #5 (permalink)
Thanks, this worked.
Old 05-02-2007, 06:50 PM   #6 (permalink)
Glad that helped.
scottjb is offline
